AdrianCR (29th August, 2019), amishmafia00 (3rd May, 2014), nakaness (20th September, 2013), viercha (25th September, 2013)
how to use the file ? thanks very very much
I only know it is dng or reg file?
Hi guys,
Update for EST 7.2.0.0
Password for the archive: est7200
https://rapidshare.com/files/1521156...0_update_1.zip
https://rapidshare.com/files/6791676...0_update_2.zip
Damned if I can work out how to make link belt come up.........
Got an idea, but dont have the time to re-install cnh to do so......
Also Wondering if anyone out there is able to supply me unmodified files for CNH 6100, so I can compare with the modified files I have here and try and make a 7200 without time limts....... PM me if this is mildly possible
Has somebody solution of EST 7.2 with Win 7 64 bit or 32 bit?
How can I use the above dongle for Win 7?
Which Sentemul can use or translate that dongle?
Thanks.
Just playing around with the Time Stopper program (posted up the thread somewhere) and EST
I have found, When you install EST, using the date set on your computer to a date that EST will accept (for EST 7, a date somewhere in 2011). for EST 7.2 a date somewhere in 2012.
Once you have installed it, install Time stopper. then create a link to pcst.exe with it.
Now..... every time you change machinery, pcst.exe re-loads itself.
Here is the trick:
rename c:\pcst\bin\pcst.exe to c:\pcst\bin\pcst2.exe.
edit the time stopper link and change the command to include the pcst2.exe not the pcst.exe command.
Now you can re-set the date on your computer.
Whenever you load EST with time stopper it will run without problems. when you change machinery, it will close as it cannot find pcst.exe. simply run pcst2.exe via time stopper and it will reload with the machinery you have just selected.
If some bright spark out there wants to write a small exe file called pcst.exe that simply calls time stopper, this would work as if it was non modified.
Futher to my last post. here is a new pcst.exe file.
you need to have time stopper installed and you need to have renamed the origional pcst.exe to pcst2.exe and it will work.
Copy this file to c:\pcst\bin
Remember thanks and PM me for the password.
BTW this will work with any version of est.
re-download this file. I forgot my own password!
Last edited by truckcomm; 6th May, 2012 at 01:02 PM. Reason: forgot my own password
Hi guys!
can anybody check is there any workshop manual for O&K MH4PMS (1999) in the EST, please.
Thanks!
