Please can you send me the password? Your pm is full.
Thank you
Thank you
Autocom CDP+ board single and double board
I have new image from the chip with no markings.
Need help with identifying this chip U 1201
hello to all member here
please i have a problem and i want to have any idea about it
so, i have an autocom CDP+ work now fine with cars but when i use it with truck no communication i receive the message that no VCI plug, i have tasted with 2 diffrents PC ofcourse i have instaled the soft of truck then make update to the CDP+ no chance after that i tasted again with cars it works fine. after that i bouth another VCI cdp+ always the same thing the seller said it is 3 in 1 means it works with cars and truck.
please is any one have an idea about this
thanks in adavance
Pics of CDP+ 1 board and 2 board both with speaker and without bluetooth
both no issue with firmware upgrade, work on 2013.3 well
i have read that 1 board version is better then 2 board, it's true??
ProTuner since 1999
can you read what type of IC is U1003 from relay board ?
I have CDP+ with 2 boards , no bluetooth. Software version 2013.3.
No connection with BMW E60/E61, and strange, no connection with Audi A6 2005 gearbox ( tried it before and work on 3 another cars same type including this one).I have tried with Wurth WOW and same result.
I have checked relays on board, all ok,next I will try to replace 9241 and try again.
Did somebody have same problem or solution ?
Here is pic of the boards :
usually no 9241 chips in cdp+
Ok. Then it must be another VCI version?
Here are pictures from back of the mainboard, there are two 9241A chips .......
Looks like nobody knows.
Maybe knows someone what types are U1000, U1001, U1002 and U1003 on the relay board.
Wrong info..sorry
Thanks m8. I will try and post results...tested....I have only 4,6V.
Tomorrow i will get some 6v2 Zeners
Hallo,
Who know where is best seller with good working cdp on dhgate.com ??
Thank you
I need some help, I am missing on my pcb board the U1201
I find out that U1201 is an RC network. (emi filter?)
Any forum member know the specifications?
Hi, maybe someone had same problem? I have autocom cdp+ china clone, after update to 2013.3 or it is coincidende, now i can connect to modules, read/erase fault codes, but none of live data parameters works. it just hangs waiting and nothing happens. Maybe someone have a solution? Thanks
