Page 34 of 94 FirstFirst ... 2429303132333435363738394484 ... LastLast
Results 496 to 510 of 1400
  1. #496
    Oct 2008
    On Earth
    There's no risk for the interface but one of chinese clones cannot do the firmwear upgrade and you have to go back to 2011-1
    Good luck
  2. #497
    Senior Member makadam's Avatar
    Nov 2010
    EUROPE
    I recently buy another autocom because first one has a problem with opel (tested 3 cars) and some mercedes car C series. Second Autocom work just fine with opel but when I open autocom I noticed some differences between them. On first one that doesn't work on Opels there is OKI chip needed to connect with FORD and on working OPEL autocom chip is missing. Also there is a small diferences in elements and PCB is same on both.
    So version 1 work with OPEL not with FORD and second one work with FORD and not with Opels.
  3. #498
    Nov 2010
    EUROPE
    Quote Originally Posted by damiantucha View Post
    In china autoc... resistors are name
    r33
    r34
    r45
    r36
    how much ohms should be?
    Attachment 113466
    R36 47 Ohms
    R34 10K
    R33 10K
    R45 10K
    But R33, 34 36 and 45 has differnet marks on my PCB.
    So bottom left on picture is R34 10k (103), bootom right is R35 470 (471), right is R36 47 (470) and above chip is R33 10k (103).
  4. #499
    Pasig
    @makadam
    Have you try to swap the relay board and test if will work on some cars?
  5. #500
    Nov 2010
    EUROPE
    Quote Originally Posted by vergel View Post
    @makadam
    No i didn't try because i already send back autocom to seller, but i wait for replacment so i will try then.
    Did anyone find and try to add missing oki chip to autocom.
    Sent from my Samsung Galaxy S2 using Tapatalk
    We can't help everyone, but... everyone can help someone!
  6. #501
    DK Veteran bibkare's Avatar
    B & H
    I oredered two chips M6636B from ut source, waiting to come, let you know what happened
  7. #502
    DK Veteran dimitar22's Avatar
    Jan 2009
    I need pinout from the man 37 pin cable please help me i need to know on which pin from the obd cable goes to which pin on the 37 pin cable so i can use it with original man interface.
  8. #503
    B & H
    Quote Originally Posted by bibkare View Post
    Chips came, tomorrow test on car
  9. #504
    Default adapter man 37 pin
    Quote Originally Posted by dimitar22 View Post
    please check it
    In autocom k line should be on 3 pin
    Please raport
  10. #505
    B & H
    Mondeo 2001 and KA 1999 not working, i didn't test it on newer CAN based, something else has to be done besides soldering OKI chip on board
    Update:
    i got tip to change 39 ohm resistors to 390 ohm which i forgot, so another test is coming
    Update:
    After changing resistors i was able to diagnose everything except engine. Car was mondeo 2001 2.0 diesel, other modules AC, airbag, ABS,instument, immo all went fine. Any suggestion welcome
  11. #506
    Quote Originally Posted by meteor80 View Post
    Better tell us how to activate or get an keygen to do that.
    Can help, contact me in PM...
    Regards.
  12. #507
    Sep 2010
    OKI IC is "made in" from thai or japan ? if you can access immo, there should not be problems with the engine ...
    Update:
    Update:
  13. #508
    Jun 2009
    porto portugal
    hi, anyone knows where is the problem to autocom trucks dont work in volvo and in iveco? i already fix the cables but the problem is on board
    regards
  14. #509
    Quote Originally Posted by jjrp255630 View Post
    regards
    What protocol uses this trucks to comunicate?
  15. #510
    Dec 2010
    Is there any solution for those not-working with BMW's around 2004-2007 year? Yesterday I had an E90 , it didn't communicate at all. Only generic OBD.
    I have OKI inside, resistors 390R.
