Here is information about newest update to autocom. So we must wait, coz they want to add new security for program.![]()
Yeah, 1xmounth more waiting.
Last night i readed this message from autocom.se.
Sorry, was my bad.
Anyone knows what is the role of the XC68HC58 MCU inside the Autocom interface?
HI,
Any idea about what Bluetooth module can be fitted inside PCB of Autocom, I have one which the bluetooth module seems to be damaged.
BR.
Just start, and all come itself!!!!!!!
Get out PCB from the case, and try after.I think you have not antenna conected to main-board(without conector)
If working like this, solder an antena to the BT module.
Thought i would give you an update, i have replaced the resistors R74 and R75 for 390ohm and now the unit can scan 2001 ford ka ok.![]()
Hello.
I have problem with autocom.
It communicate with Ford and other brands, but it don't communicate with Opel Astra H with airbags and central electronics.
It is SW CAN. Does someone know how to repair that?
Work is a primitive way to spend Your free time.
F.Kiepski.
HI guys I have problem with MB C-Class W202 1996 year 2.0 benzina I can not connect with AutoCom ECU, Airbag, SRS, ABS...
Have you any Idea fot this solution ???
How to remove AUTOCOM 2011.1?
uninstall and clean registry if you want to install 2011.3
clean autocom entrys from reg
