Page 5 of 94 FirstFirst 123456789101555 ... LastLast
Results 61 to 75 of 1400
  1. #61
    In my cable set 4 of 8 cables are defective. Volvo 8 pin with power pins inverted, and iveco the others with pin K line changed...
    Really very bad and dangerous cables...
  2. #62
    Yes ,
    volvo is 8 pin not 12 ,my mistake,and power and gnd are inverted.
    In other cable's k-line is on pin 1 for scania,
    pin 3 for renault 12pin,
    pin 2 for iveco(30 pin)
    pin 3 for man 37 pin,
    man 12 pin is ok.
  3. #63
    Jun 2009
    UK
    Guys, is it technically possible to use CARS and TRUCKS Autocom softwares on Truck interface only?
    Now TRUCKS version runs fine, and CARS drops and error crying for correct HW ID number after checking the interface.
    BR
    WD
  4. #64
    Dec 2010
    I tested this clone unit on few cars from 2001 up to 2008 without any problem, made few coding and configurations. Looks good. But as I can see only main menu are translated to local language, but error codes and descriptions are on english.
  5. #65
    Top Poster baner's Avatar
    Quote Originally Posted by eduardo74 View Post
    I can confirm similar expiriences with Autocom clone and software release 2011.1
    Tested sucessfully even with older cars like Renault Laguna I, Opel Astra G, Citroen C3, Renault Megane, Fiat Stilo, Hyundai Tucson, Mercedes A 170, ...
    Only problem was FIAT Stilo, motor ECU connected only trough EOBD option. Tested sucessfully even with DELPHI software.
    Regard language options and translation, only a menu and menu options are localized properly on Serbian, all other including error descriptions and service procedures are good old plain english.
    Just for info: I can confirm that same hardware is for TRUCKS and CARS, Tested on 24V with adapters on Mercedes Actros truck 1999, and Iveco Daily.
    Regards and respect!
  6. #66
    Quote Originally Posted by worldiagnostic View Post
    BR
    WD
    Yes, I can confirm that CARS and TRUCKS software works on same interface.
    But you must program your Atmel Attiny 45 with correct VCI ID, which supports both CARS and Trucks softwares.
    You can even use Autocom clone with Delphi software. (again with correct VCI HW ID).
  7. #67
    hello
    what is the key for 1.2011
    abd what is the correct hw id
    best regards
  8. #68
    Jun 2011
    what is the key for 1.2011, what is the correct hw id, thanks
  9. #69
    Jun 2011
    lati, you know the key and hw id for 1.2011
    best regards
  10. #70
    Lithuania
    Hi!
    Would anyone can tell me what is it mb 38 pin to OBD 16 pin cable diagram?
    Sorry for me english.
    Thanks.
  11. #71
    Quote Originally Posted by auris View Post
    Hi!
    Thanks.
    hi
    38 pin mnercedes diagnose connector(car)
    38pin obd
    1 gnd 4&5
    3 12volt 16
    4 k-line 7
    for 38 pin mercedes truck:
    38pin obd
    1 gnd 4&5
    3 12volt 16
    10 k-line 7
  12. #72
    Lithuania
    Yet another question.
    Autocom use their own multipexor, or need to connect manually to diagnose other systems (ABS, SRS ...)
  13. #73
    If you mean that the interface will do automatic changes of active pin of OBD connector, then you are right, it will do automatic multiplexing. You do not need any additional manual switchbox/breakoutbox to change active pin.
  14. #74
    Lithuania
    What is a full cable diagram(16p to 38p)?
    Thanks.
  15. #75
    Dec 2010
    Can anybody confirm that interface for cars can work with truck software? Is there any possibility to destroy interface if working on 24V or 28Volts?
