Page 55 of 94 FirstFirst ... 545505152535455565758596065 ... LastLast
Results 811 to 825 of 1400
  1. #811
    Ashraf6119's Avatar
    UK
    Quote Originally Posted by galiza View Post
    With the version 1250,Can it be updated firmware whit 2012 R2?
    Yes as long as your Interface is of GOOD QUALITY............. Also make sure when updating the Firmware the vehicle battery is fully charged or keep the engine running..........
    I personally keep engine running.................
    Thanks Ash
    Oh yes if my post was helpful than Please don't forget to press the Magic word Thanks
  2. #812
    autocargo's Avatar
    Quote Originally Posted by MJRVR View Post
    Hi thanks for the info.
    Upon reading up on it
    I believe the firmware has been erased from the 29F800 chip.
    I did ask the suppliers who supplied it to send me a new chip but they refuse they say I need to send it back at my cost. Really not worth doing.
    I havent a suitable programmer to reflash the said chip I only have the UPA.
    Martin
    I still believe that it only needs re-flowing. I've had one with same problem and that's how was fixed. After re-flow autocom interface should be found on usb ports. Then you can update firmware. You can try m8 there's nothing to lose.
  3. #813
    Aug 2011
    Spalding
    Quote Originally Posted by autocargo View Post
    Thanks Autocargo
    Will have a go tomorrow.
    Martin
  4. #814
    Aug 2011
    Spalding
    Hello again Autocargo.
    Are you saying your computer coudn`t find the autocom and thats why you refowed?
    My autocom is found fine by the pc via USB it just doesnt finish the update after its connected.
    Martin.
  5. #815
    autocargo's Avatar
    Martin.
    I've had both situations. You can still re-flow boards and hopefully would fix your firmware problem. After re-flowing firmware upgrading worked OK.
    Regards.
  6. #816
    Feb 2012
    yes you can, i do this many times all working perfect!
    i can activate new Autocom 2.12.2 - Delphi
    write my to PM i told my email for contact
    sorry but this not free
  7. #817
    Quote Originally Posted by lupu_sandu View Post
    Old autocom HW
    in your opinion wich from the clones one have the improved hw?want to buy one and there are just to many versions,you can no longer look through.
    regards
  8. #818
    Quote Originally Posted by sepistar View Post
    regards
    My advice for you it to buy from a seller from your city.He had test the interface, and offer warranty.If appear problems you can meet with him and explain him the problem.But the cost will be biger with some $$$
  9. #819
    Oct 2012
    Hello, the Autocom is a good interface for both cars and trucks diagnose, I've used it and it went very well especially from European brands, Volvo, Peugeot, Renault.
  10. #820
    Jun 2012
    Lviv
    Hello!
    My Autocom not working, opel Zafira B SRS Airbags not connection? maybe not working SWCAN, how it's repair, thanks!
  11. #821
    Jun 2011
    Italy
    Quote Originally Posted by Raulmax View Post
    I tried it on Iveco Stralis & 2 Autocargo 2005 & 2008 but cant connect!
    did you make any fix or can post a quality pic of yours ?
  12. #822
    Autocom is a very good interface for this money.How you pay, like that will work.But is better like others.
    For example i write 2 key on VW Sharan after i had extract the Pin with another tool.
    And on Skoda Superb who have problems with key lock driver door, i have adaptate remote control in 5seconds.
    In my contry(Romania) we have a talk:
    " Vrei si cu pula in cur si cu sufletul in rai"
    That means:
    "You wont **** in ass and soul into heaven".
  13. The Following User Says Thank You to flavyus1987 For This Useful Post:
    TR0UBLESH00TER (3rd April, 2015)
  14. #823
    titoun's Avatar
    Dec 2010
    Quote Originally Posted by solar View Post
    i have some problem with autocom 2011.1.
    autocom not work anymore,i try to reinstall software,try on different laptops same result:
    try to connect to car no communication,so i go to settings to do hardware setup and here then i try to look for com port(automatic or manual search),i see no communication+firmware not loaded and another table with***incorrect firmware version,please update your firmware***i try to do updates(connect to car wait around 5 min.) and all process was OK,but when try again to locate com port again same story...divers looks Ok,computer recognize autocom(vci device found),but something missing...............maybe,anyone have same problems?i check all connections,soldering, maybe problem in 29f800.......here my file of this chip....any ideas?
    Do you have resolved your problem of communication with your AUTOCOM; i have a same problem ???
    Do you have reflash 29F800 for resolved problem ???
    Regards.
  15. #824
    Top Poster ioanrokos's Avatar
    Thessaloniki Greece
    Quote Originally Posted by titoun View Post
    Regards.
    if the problem remains, try connect via BT. Perhaps your FDTI chip has colapse or bad soldering
  16. #825
    Harrycz44
    Guest
    Hello I need connect Iveco Daily 2001 have someone schematic for adapters 38pin Iveco to CDP pleas? thanks
