Page 18 of 94 FirstFirst ... 813141516171819202122232868 ... LastLast
Results 256 to 270 of 1400
  1. #256
    V.I.P. Master of the IMMO
    lupu_sandu's Avatar
    Jul 2009
    Far far away
    This MCU is for Ford protocol
    Change this and your autocom will work on Ford cars non-CAN.
    This method is tested by a friend.
    Datasheet and picture of MCU attached:
    4C7570755F73616E64755F696D6D6F5F736F6C7574696F6E73
  2. #257
    autocargo's Avatar
    Thanks lupu_sandu, you are very helpfull. Do you know where from we can buy that MCU? So far I couldn't find anywhere...
  3. #258
    Nov 2009
    somewhere around here
    Have you tried RS and good old fleebay?
  4. #259
    Dec 2009
    Quote Originally Posted by lupu_sandu View Post
    Can you try this repaired autocom on BMW E60 or E90 from 2004 to 2006(7) ?
  5. #260
    Dec 2009
    Quote Originally Posted by autocargo View Post
    Got exactly the same problem on mine. Can't read engine ecu on Mondeo 2002 (petrol engine) it works OK on other modules. Don't have another Ford to try it on... hopefully someone smart will come with a solution. Mine seems to work OK on one Audi and one BMW. So far only had 3 cars to try on...
    Can you try your autocom on BMW E60 or E90 from 2004 to 2007?
    I'm trying to figure out if the FORD problem is corelated with BMW preoblem...
  6. #261
    lupu_sandu's Avatar
    Jul 2009
    Far far away
    No m8. Ford ECU use SAE protocol J1850 and comunicate on pin 2 and 10.
    BMW use k-line (pin 7) and another protocol (kwp2000 or another).
  7. #262
    Dec 2009
    I know, look here:
    BMW TIS - OBD socket Standardised layout of the OBD socket Standardised pin assignment Pin 1:
    Some autocom I have work on pre 2004 and after 2007 BMWs, bot no way on E60 and E90 from 2004 to 2007!
  8. #263
    Oct 2008
    On Earth
    Quote Originally Posted by alfy View Post
    I know, look here:
    Do you think about pin 1?
    Pin 1 it is ingnition ON
    Pins 7 and 8 K-line ( but not in all car )
    Pins 4-5 - GND
    Pin 15 - L- line ( but just in cars up 1997 - ADS protocol ) - you do not need it in OBD cars
    Pin 16 - +12V
    Good luck
  9. #264
    Dec 2009
    Quote Originally Posted by mattydr67 View Post
    Pins 4-5 - GND
    Pin 16 - +12V
    Good luck
    Hi!
    I know the pinout, all seems OK, but some autocom's won't work on these cars... I wont to know why!
    If I use Generic OBD function can comunicate with ECU!
  10. #265
    Meat-Head's Avatar
    Hi!
    Just for reference Shitroen C3 1.4 HDI - 2004 - not able to talk to engine ecu
    via EOBD - anytool - but dedicated Shitron only
    Meat
    Last edited by Meat-Head; 23rd December, 2011 at 09:32 PM. Reason: DAMM FORGOT MODEL
  11. #266
    DK Veteran Amine13's Avatar
    Aug 2009
    Which model of shitroen () M-H?
    Just start, and all come itself!!!!!!!
  12. #267
    Meat-Head's Avatar
    Quote Originally Posted by Amine13 View Post
    Sorry was excited and forgot to say Shitroen C3
  13. #268
    Aug 2009
    One of the Guys I know tested on Peugeot 307 2003, and the problem was that Autocom didn't communicate with any module; so please get test for this model, fault XS evo interfaces were used not to scan it too, something special for PSA cars related to Their VAN protocols. PLease make full ecus tests on this model to confirm Autocom working on them.
  14. #269
    autocargo's Avatar
    I would sure try m8 but I think will be a while before I will come across one. Today tested successfully on Shitroen Jumpy year 2007 diesel, BMW 520 petrol year 2000, Ford Fusion diesel 2004 (probably on CAN protocol) also tested on Focus diesel year 2000 but only worked on ABS and another 1-2 modules (can't remember which ones) not working on ecu and other modules.
  15. #270
    meteor80's Avatar
    Dec 2009
    Poland
    My Autocom works fine with Citroen.
    Tested with:
    C5 2003 2.0HDI
    Berlingo 2.0HDI and 1.6 Petrol
    C3 1.4 HDI
    Peugeot 307 1.6Hdi and 2.0HDi
    But it doesn't works with honda Jazz old model- tested on 2 cars.
    It must be problem sowewhere in electronic,and must be couple producers of Autocom's.
    Work is a primitive way to spend Your free time.
    F.Kiepski.
