test and report
test and report
tried that dump, but there's no connection with the airbag ECU with the diagnostic equipment - before, with the original dump the communication could be estabilished without a problem
This should be fine.
br
thanks! will try and report
when the ignition is switched on the airbag light goes out, and after a while it goes back on - so it seems like the airbag system is functioning, but there's a fault
and before it used to flash the hazard lights every time the ignition was switched on, but now it's OK
but still, no communication with the airbag module
and most of the other componenets store a "no CAN communication with the SDM unit" - that is the airbag ECU
What the hell could be this?
Your problem solved?
I have identical problem with 13188857 astra H SDM , after clear crash data ( 100% ok solution) SDM no communication with all another module in car and not comunicating via diagnostic . Maybe flash is corupt , my eep is 100% ok clear. Maybe someone would like orginal flash to this SDM motorola 4L40K .
Hi guys
Same problem for me. I've reading and writing that with upa. Now airbag light first off than on, no communication with all another modules.
Any idea??
youbhave wiring diagram pinout
hi
check this pls
