Results 1 to 11 of 11
    DK Veteran VTS_Tibi's Avatar
    Nov 2009
    Hungary
    Default Opel Astra H Temic airbag ECU crash data reset
    Hi Guys,
    I would need the crash data to be erased from this dump.
    It is from a 2004 Astra H with Temic airbag ECU - 13 191 825
    The dump is from a Motorola MC9SDG128E.
    Regards,
    Tibi
    Jan 2011
    from away
    test and report
    Nov 2009
    Hungary
    tried that dump, but there's no connection with the airbag ECU with the diagnostic equipment - before, with the original dump the communication could be estabilished without a problem
    morfej's Avatar
    Dec 2008
    This should be fine.
    br
    Nov 2009
    Hungary
    thanks! will try and report
    szkeptmen's Avatar
    Jan 2010
    Hungary
    Quote Originally Posted by hafido1983 View Post
    test and report
    Wrong solution !
    You MUST leave data on hex 210...284
    WBR
    Nov 2009
    Hungary
    when the ignition is switched on the airbag light goes out, and after a while it goes back on - so it seems like the airbag system is functioning, but there's a fault
    and before it used to flash the hazard lights every time the ignition was switched on, but now it's OK
    but still, no communication with the airbag module
    and most of the other componenets store a "no CAN communication with the SDM unit" - that is the airbag ECU
    What the hell could be this?
    Nov 2009
    Quote Originally Posted by VTS_Tibi View Post
    Your problem solved?
    I have identical problem with 13188857 astra H SDM , after clear crash data ( 100% ok solution) SDM no communication with all another module in car and not comunicating via diagnostic . Maybe flash is corupt , my eep is 100% ok clear. Maybe someone would like orginal flash to this SDM motorola 4L40K .
    geocity's Avatar
    May 2014
    Hi guys
    Same problem for me. I've reading and writing that with upa. Now airbag light first off than on, no communication with all another modules.
    Any idea??
    Jul 2016
    anywere
    youbhave wiring diagram pinout
  11. #11
    May 2019
    hi
    check this pls
