Results 1 to 15 of 17
    Default seat ibiza 03 no can bus lines to obd connector
    hello to all mates
    i have a seat ibiza 03 1800 turbo 20v
    i have errors to all modules (vcds) can bus communication......
    engine
    dashboard
    airbag
    steering
    abs
    immobilizer
    climate
    ...............the car starts properly but on the dashboard all the lights flashing.......tachometer speedo and the gauges works good......
    i check to the obd for 60ohms to pin 6and 14 of can bus lines but i havent got.....i check for wiring cut behind the radio but the wires are good....(no cut)
    what else have i to check????
    What are you trying to do? Are there any dtc registered?
    This car haven't got canbus lines on Obd connector, it only has k line.
    On this car canbus is only for comunication between several control units, but not for diagnostics.
    so if this you tell is true,why has wires to pins 6 and 14 to obd mate????????for beautiful????this car has can high and can low to obd......
    OK, then I will consult the wiring diagram for this car. As I know the diagnosis is made only by k line.
    I will try to find out about the CANbus in this car.
    Regards.
    the diagnosis made by k line....
    but on obd has can......
    i suppose that the problem is to body computer
    Liteace's Avatar
    Mar 2009
    On a rock
    Whats the engine code ????
    Could you write here your vin and engine code?
    Liteace's Avatar
    Mar 2009
    On a rock
    It has got can on dlc, it goes from dlc > dianostics interface \ power distribution module > engine, dashboard, airbag, steering, abs, immobilizer, climate. you need to unplug all these one by one and see if you get coms back, have you got a scope you can check can high \ low from the DLC. Is the engine code BJX ??
    Liteace's Avatar
    Mar 2009
    On a rock
    A - Onboard supply control unit
    Connector:
    - XS1 - T6, 6-pin connector, (black)
    - XS2 - T18b, 18-pin connector, (black)
    - XS3 - T6w, 6-pin connector, (brown)
    - XS4 - T18, 18-pin connector, (brown)
    - XS5 - T6g, 6-pin connector, (red)
    - XS6 - T16b, 16-pin connector, (black)
    - XP1 - T6k, 6-pin connector, (black)
    - XP2 - T6c 6-pin connector, (brown)
    - XP3 - T6ad - 6-pin connector, (red)
    - XP4 - T5, 5-pin connector, (black)
    - XP5 - T5a, 5-pin connector, (brown)
    bjx engine code......2006 model....sorry for my mistake(2003 model)
    Pin 6 on obd comes from pin 6 of XS6-t16b and pin 14 on obd from pin 2. Check if all connectors are plugged correctly.
    can i check something inside this for fix or go for other????new or second hand??
  13. #13
    Liteace's Avatar
    Mar 2009
    On a rock
    Quote Originally Posted by d.zio View Post
    sound like connection problem, short to + or ground on can, water ingress somewhere or even a module playing up, on each connector you have only 2, 1 for can high 1 for can low. With a bit of investigation you should find the problem
  14. #14
    now the customer told me the truth......he had the car to an other garage before two months..........they put to him an other body computer from polo he told me........but he had the same problem.....now he brought me the old one...i put it on the car and i have the same problem....
    in my mind can i suppose something????if the the body is good(suppose) can the airbag unit do this problems if has water inside????
  15. #15
    Liteace's Avatar
    Mar 2009
    On a rock
    Try abs pump / module first, I can't see airbag ecu with water ingress but you never know !
    Sent from my crapfone using sausage fingers
