Hi lads n lassies. I am loading the software for a friend on a starview one but on the download, there is 2 files and I am not sure which one to use? Also, I am not sure if it is a clone box? Can i tell by looking at the remote control? Cheers all
If you are unsure use the Cryptstar257 bin, as it is fine for both clone and genuine boxes.
im now having problems cant seem to be able to get the software onto my box any body help please?
I have tried to open GTrom 4.0 but it comes up all wierd can you please help
Hi There
Will this fix work for all the clones boxes ?
Thank you
superb guys
Excellent work with this new BIN file! Got it loaded onto the box grand. No channels coming in though when doing auto scan
Box: Starview 1 Original
Provider: UpeeC (ch0ru$ and NteaL merger)
Problem: No channels / radio stations after scan on NteaL provider
It was working in Dublin but i recently moved. I am presuming i need a channel dump file for Midlands Ireland - does anyone have one?
Ta much!
Is it an MMDS feed or cable? Is there a mesh aerial on your roof?
Not too familiar with all of this but...
Almost positive it is cable - how would I tell if MMDS?
Again, almost positive there is no aerial on the roof (i wasnt in the house when the UpeaC guys called) but will check tonight
I spoke to a guy I know over there and he is almost sure it is MMDS or it may still be analogue only. Best checking a bill it will say what type of service they are providing you with.
Do you have a box supplied to you by UP*? If so is it a Sagem or Pace? Check underneath if it says ITD on the label it is MMDS.
Well, checked last night.
It is a Pace box - couldnt see anything related to ITD.
I have an invoice type sheet that has checkboxes for Network, Signal, Frequency, Level Tap etc. I have scanned it so i can send it to your email if you PM your address to me?.
From what i can see cable is checked for network, signal is QAM Tap Vaule is 4/11? But i could be reading this all wrong!
I have sent you an address to send it to, may I have someone I know in that general direction take a look at it?
AFAIK it is Chorus but may still be analogue, but I will come back with a definitive answer once I relay your info.
thanks the advice really helped
