Thx.
SOP file how to decrypt?
check out this new tool for SCANIA parameters programming
SCANIA SDP3 SOPS file editor decryption / encryption
Thx.
Help me!
How do I download from the site?
As i know only 3 company has sops decryption tool.
And all of them sell it copy protected, so best of all try communicate with autokg and buy it, or decrypt it by your self...
But not all changes as it describes...,because some things even changed in sops not change in hardware... you need just try what, and then ask questions to seller....
I never hear that some one has it for free...
If someone could "cure" attached it would be
allobd2 (27th February, 2018)
Node32 found the "SOPSXMLEditor_diagnostic55.com.exe" file as virus. Is it really a virus?
Does anyone used the editor to disable the AdBlue Scania R420 from 2010 with EMS DC1215 L01 S6 or another Scania?
Apparently when switched off, the information (lamp) remains on the dashboard with error ?
on teory is possible dissable
I recomend to put your's sops file here, may be some one can help you.
Converting EURO5 to EURO3 using SOPS editor
In ECUBlock remove all values.
In FPCBlock change:
2471 to "A"
3458 to "Z"
3459 to "Z"
3476 to "Z"
3488 to "Z"
3636 to "Z"
3647 to "ZZ" (Level Sensor Polution Urea)
3719 to "ZZ"
1837 to "A"
In UFCBlock delete entire 376, 377, 378 blocks.
Replace UFC 384 block with the one below:
<UFC Name="384"><UC Name="340"><SCN Name="475"/></UC></UFC>
In CableListBlock delete blocks: 1546040, 1865584, 1865588.
In VersionBlock add to AffectedEcus=" DAS1, ICL, OPC, RET, EMS, EBS5, EEC3, ELC3, TPM1"
if 3659 = "A" leave DAS1 in AffectedEcus
if 4280 = "B" leave EEC3 in AffectedEcus
if 3133 = "A" leave EBS5 in AffectedEcus
if 3135 = "A" leave ELC3 in AffectedEcus
if 3549 = "A" leave TPM1 in AffectedEcus
Other ICL, OPC, RET, EMS decide by situation if exist leave - if not remove.
Make VersionNumber of IMP file by one number higher than was in EXP file.
diboa (12th September, 2013), masterecu (2nd April, 2022), polacorti (18th October, 2019), timbermoto (8th April, 2013), youssef70 (20th February, 2016)
I can decode SOPS and CODE it back if somebody want. PM me.
thanks for that information
MagicMotorsport FLEX, Kess / K-Tag original, PCM Flash, MMC Flasher, BitBox, 2wd Dynomet Dyno Road, Ori WinOls.
We offer: Cars, Trucks, Agro, Construction Machines Tuning / DPF / EGR / Flaps / Throttle / Ad Blue / Lambda / DTC, IMMO off. Also EDC17 IMMO off BY EEPROM with no faults on a dash!
