Results 1 to 11 of 11
Hybrid View
    May 2011
    Default technomate tm600/500 sound problem
    I have a technomate tm 600 and it has been working for a year now without any problems and recently on all the Disney channels and s*y movies the sound has disappeared . I hv seatched all over the Internet and could not find any solutions . disable was on 4:3 is disabled and ac3 default output is enabled, I hv tried changing these but there is no effect. the box is connected through a scart straight into my 50" flatscreen tv. thank you in advance
    DK Veteran bj1's Avatar
    Sep 2010
    north wales
    have you tried rescanning 28east it worked for me when i had the same problem
    May 2011
    I rescanned all the transponders, but no luck . I'm pretty sure that it is to do with the settings or it may be a technical fault thankyou for your quick reply too bad we lost
    Sep 2010
    north wales
    have you got a phono lead ? try that ......did you buy your box preloaded?
    May 2011
    yes, my box came preloded , I pay per month to a guy, I managed to get the pin code from the guy and he taught me how to scan for transponders, I am connected by a scart and it was working fine until I changed the setting not to send wss signal when 4:3 ,the sound stopped working then . I hv tried reverting the settings back and fourth but it still hasn't worked.
    Sep 2010
    north wales
    have you tried switching between rgb and pal
    DK Veteran freck's Avatar
    Jul 2008
    Dark side of the Moon
    Try pressing the "audio" button on your remote and change the audio setting to English.
    Freck
