Configuration files
A few pages back someone said it was possible to run two version of these cracks on one computer . By changing the location of the configuration files . How is this done ?
Configuration files
is there any way to make a project or map pack (.kp) backward comtatible or readable for a older version?
e.g. v1.500 wants to read projekt or map pack from 1.7 or newer demo version?
It is also possible to save/export projects in latest 2.00 32b demo found on evc.deMagik
give more details about how this is possible![]()
And . Please if anyone knows how to run two versions on one computer without the configuration settings being deleted on start up let us know . This was mentioned that it could be done
hi,
ihave the problem thaht the keyboard shortcuts are not working (ie. shift+%).
How can i solve this?
br
thank you very much...
but I've some little problems... installed on windows xp sp3, starts perfectly but can't save the project, when edit the project data an error without specification appear, and the same happens when I click "OK" ...
I'm looking for 1.7 winols no bugs, the exchange
Hi guys,
Does anyone have the following plugin:
OLS807 - Bosch MED17 (Version 2.33 or higher)
I have version 2.16 but need the latest version right now.
Best regards
Sam
the patch.exe need code to open ..... what is;
I'm afraid the bug-free version is not yet leaked, not sure if it will ever be. Only sold, from what I can tell..
Come on people, it's 150 now, grow some balls! :P
cheers
If freedom is outlawed, only outlaws will have freedom!!!!
works perfectly, currently I have the two versions installed..will remove the older one when i make sure the newer is rock solid
