Page 1 of 10 123456 ... LastLast
Results 1 to 15 of 147
    Default Professional Tuned File Request Citroen C5 1.6hdi
    Anybody can make a professional chip-tunning. I still can not grasp all the subtleties. My car has an engine 9HZ 16v 110cv, ECU EDC16c34. I would be very grateful for the help
    I want to tune this car to the max power of this engine. Wishes: I would like to gain power
    began with a 1200 RPM, and even in this firmware is successfully disabled EGR (no errors on it) but want to increase the discharge pressure turbine
    especially at idle.
    sorry ori dump:
    Moon
    If you want professional help ... you have two options.
    1. go to the local tuner
    2. do your homework, show that you are working on the file, post here the results and maybe then someone will guide you on the right path.
    Or you can try a non-professional remap +10 +20% on all maps
    ALGERIA
    don't go to a local tuner P2XA
    your will paye 200euro for a poor quality chiptuning
    as your freind is grinovsky your dump will be remaped
    and please repport for result
    DK Veteran lee_hdi's Avatar
    Sheffield
    Quote Originally Posted by bazare View Post
    Totally agree.
    For all we know, you could be requesting this for a client and charging them ?300-400 for 'your' tuned file.
    DK Veteran rappttor's Avatar
    PERPETUUM MOBILE
    good point, and trust me, there is some guys here who made good money in this way...
    Thanks to Grinovsky. Really hoping for your support and understanding.
    ALGERIA
    P2XA how did you disable egr on this EDC16?
    is there probleme after make egr off on this EDC16?
    I tried myself to solve this problem but could not (there was an error that the data from the ECU wrong, the excess boost pressure). But then I went to a forum with this problem and mysamed resolve my problem (no errors damages caused EGR). The only drawback is that the high boost pressure even at idle ~ 1100-1150mBar. In general, need to adjust the turbine control dumping.
    I can lay a dump from this machine without FAP to compare
    ALGERIA
    so,i see in your dump that all the egr map is set to 8080
    and the egr is not desactived it's only programed to be closed in your edc16 ;did you trayed with highst values 10000 for exemple?
  13. #13
    Dec 2010
    UK
    If you try at highest value on EDC16, ECU will detect an incorrect reading through MAF and bring up an anti-pollution fault.
    As a "technician diag electronic engine" you know this, right?
  14. #14
    I don't tryed with hi values 10000?
  15. #15
    But egr RCO is 0% always
