    South Africa
    Default system date keeps changing
    Hi All
    Every time I switch my pc on the date is wrong , could it be a flat battery ? The reset date is always the same .thanks regards .
    cunny's Avatar
    Jan 2009
    The Shoutbox
    Yea there will be a cell battery on the main board of the pc, change this, and should be fine again. When a battery dies it goes to default setting with date and time too
    Nov 2010
    As said above its the battery on the mobo, the date as well as some bios settings wil default usually its the date and time.
    Change it and all should be back to normal.
    South Africa
    thanks guys
    my 19 yr old said so
    just checking
    ta regards
    DK Veteran BRASS EAGLE's Avatar
    Central Scotland
    i would go with that change the battery
    DK Veteran jetdede's Avatar
    Nov 2010
    under carter
    maybe it will working but long ago i got same problem and change BIOS battery but same problem still happen even have change value in BIOS for date etc....
    so i got new one MB (because the problem happen to my old MB)...it's fix everything.
