Page 5 of 5 FirstFirst 12345
Results 61 to 75 of 90
Hybrid View
    DK Veteran cocoh's Avatar
    Jun 2009
    Quote Originally Posted by Vladimir.CDI View Post
    I found, that after I apply cal872.exe fix Xentry goes to error similar to that (see attach). Reinstallation Xentry only makes it work againg, but after cal872.exe it is again go to an errror
    it is valid both SIM mode and real car mode
    Can somebody confirm that? To evaluate that just try to run short test on 212/204/207 in SIM mode
    I don't have this problem....
    My setup did download AddOns (I did not allow it to install all of them). All I did was activating the network connection through WLAN. PC date must be correct I believe.
    If installation of 05.2011 terminate with error.
    DAS is not in fully installed. Many files are missing.
    Default Xentry Mar 2011 error
    I install 03/2011, when I use xentry after select model and run initial page battery show 13.9V. and ignition status on after initial page run finish have error battery and ignition status no display, see attach file.
    Help me, How can i do.
    Thank a lot
    Paraguay
    Quote Originally Posted by signupna View Post
    Thank a lot
    Please check your DB9 solder !!
    recently receive clone-mux from china
    works fine with VM 03-2010, after install 05-2011 got cal 872.
    change in cal.ini PART_D -> PART_D2 - solve problem!
    Bogota Colombia
    Default DAS Large Hard Drive Fix
    hello
    plis i need the DAS Large Hard Drive Fix for install das 07-11
    my hard drive larger than 120GB ( 150GB)
    impactops's Avatar
    Quote Originally Posted by antioqueno View Post
    hello
    http://www.digital-kaos.co.uk/forums...ml#post1269837
