edsontec2007 (24th July, 2020), Wayne Techiemec (14th August, 2020)
Thankx Friend, but Below is Crack for Expiry ........
to avoid expiry you will need to modify two files namely the esdninfo.dat file and the ***.mdb file for each required calibration folder.
1: Open the following on your incal disk:
*:\INTELECT\ESDN\esdninfo.dat using notepad,
The following information should be displayed:
[Information]
Requiredbytes=100000000
Date=10058
DisplayName= "March 2010" (you can replace the display name with whatever you want to be displayed when you open the calibrations in Insite e.g DK Rulez, Cummins Calibrations e.t.c for a more custom setup.
The date is in Julian calendar format where 10 represents the year 2010 and 058 the first 58 days of the year 2010.By altering the date either 6 months before or after the present date the incal image you creating will be accepted by Insite as valid.Insite seems to to take the following month of julian date as the accepted month.
2: Open the following in Winrar
*:\INTELECT\ESDN\DATA\***\***.cmp\***.mdb where *** is the calibration file e.g ECI, CPI, or C94 etc.
When you try to open ***.mdb you will be prompted for a password try either ndse or ocec which are case sensitive (special thanks to Simmax for providing these passwords)
Open CALDATE datasheet. Modify the Caldate to match the esdninfo.dat date and time. once done save changes and calibrations are now valid. modify ***.mdb file for each calibration you require.
Hope this helps. If so use Thanks button.
Wayne Techiemec (13th August, 2020)
CAN ANY ONE HELP FOR QUICKSERV ?? I ALREADY HAVE DVD BUT ITS NOT LIKE A quickserve.cummins.com..........
Can you check the files and reupload the ones are fallen ?
Thanks and regards
I am get it without any error .
All parts is good .
FU#K GOOGLE. ASK ME
All links downloaded ok for me with rapid manager
You have reason guys, seems to be a problem with my jdownloader. I am trying to download it manually and at the moment all the links work.
PD : Drizzt please, check your inbox and send me the password.
Regards!!
apology, to extract the file marked as damaged HD part 05, thanks and regards
Sent pm 2 days ago for pass
Trucks, check your inbox.
I'm pretty much ignoring the leechers (aka "Newbies") ... Trying to just share with the people who actually contribute around here.
hello dk friends Ineed a may 11 incal dvd cant? somebody help please? apreciate on advans
Hi, thanx alot, pls send me passw.
hi thanks for the incal. may I have the password please?
