Page 2 of 5 FirstFirst 12345 LastLast
Results 16 to 30 of 67
  1. #16
    Aug 2010
    Default Password
    I tried to download but it requests a password. Can you send it to me?
    Thanks,
  2. #17
    Junior Member Attach's Avatar
    Hi friend,
    Can u giveme the pass please?? (Check Inbox please)
    CHerrsss!!
  3. #18
    Dec 2010
    COLOMBIA
    I update mu jdownloader and I did not have problems to download
  4. #19
    Mar 2011
    For all of you with "Newbie" status, don't expect to get the password. Try contributing to this forum before coming here and just leeching away. This is one of the reasons we decided to start putting passwords on everything!
  5. #20
    Australia
    I have sent a PM asking for the pasword as well , did i come under a leecher ?
    Quote Originally Posted by drizzt4321 View Post
    Trucks, check your inbox.
    I'm pretty much ignoring the leechers (aka "Newbies") ... Trying to just share with the people who actually contribute around here.
  6. #21
    Quote Originally Posted by bravealikhatri View Post
    Thankx Friend, but Below is Crack for Expiry ........
    to avoid expiry you will need to modify two files namely the esdninfo.dat file and the ***.mdb file for each required calibration folder.
    1: Open the following on your incal disk:
    *:\INTELECT\ESDN\esdninfo.dat using notepad,
    The following information should be displayed:
    [Information]
    Requiredbytes=100000000
    Date=10058
    DisplayName= "March 2010" (you can replace the display name with whatever you want to be displayed when you open the calibrations in Insite e.g DK Rulez, Cummins Calibrations e.t.c for a more custom setup.
    The date is in Julian calendar format where 10 represents the year 2010 and 058 the first 58 days of the year 2010.By altering the date either 6 months before or after the present date the incal image you creating will be accepted by Insite as valid.Insite seems to to take the following month of julian date as the accepted month.
    2: Open the following in Winrar
    *:\INTELECT\ESDN\DATA\***\***.cmp\***.mdb where *** is the calibration file e.g ECI, CPI, or C94 etc.
    When you try to open ***.mdb you will be prompted for a password try either ndse or ocec which are case sensitive (special thanks to Simmax for providing these passwords)
    Open CALDATE datasheet. Modify the Caldate to match the esdninfo.dat date and time. once done save changes and calibrations are now valid. modify ***.mdb file for each calibration you require.
    Hope this helps. If so use Thanks button.
    bravealikhatri thank you very much, I worked perfectly.
    Can you forward more than six months?
  7. The Following User Says Thank You to jdmp33 For This Useful Post:
    Wayne Techiemec (13th August, 2020)
  8. #22
    thanks mate .. great job .. can i have the pass ??
    regrads
  9. #23
    Oct 2010
    Please send password by PM
  10. #24
    the password please?
  11. #25
    Mar 2011
    Why is it that I am constantly suprised by all the noobs?
  12. #26
    I'm lucky? or newbie?
  13. #27
    DK Veteran nilton2009's Avatar
    May 2009
    TURQUIA
    Default pass
    pass please
  14. #28
    Sep 2010
    pls pass
  15. #29
    Member ramsi17's Avatar
    Dec 2010
    Hi everyone i need passw for rar.
    thanks a lot
  16. #30
    Hi everyone.I have one problem.I recalibrate CM 850 MCRS on QSK 19 engine and accelerator lever dont work.Before recalibration accelerator worked.New calibration is AQ40060.09 and old was 40060.03.Value for voltage acelerator is different,I have to 3V,need 4.75 to 5V.Have anybody calibration AQ40060.03?Thanks
