Page 6 of 6 FirstFirst 123456
Results 76 to 85 of 85
  1. #76
    click on rar file an get nowt m8
  2. #77
    Sep 2009
    near glasgow
    [QUOTE=garyb;104040]hi all
    first post on this forum. i have searched this and other forums but cant find out if it is possible to upload firmware other than by usb stick. i have two sv4 boxes both of which died during firmware installation, one now says 8882 and the other is on the download screen stuck at 8%. is it possible to use a gtrom program from one of the other boxes? or can these boxes be jtagged. any help would be great.
    u take out usb when box was on m8?
  3. #78
    Sep 2009
    near glasgow
    [QUOTE=garyb;104047]thanks jok
    i am using v1.05 that i downloaded from the seller of the box. and that is just one file. i am now in the position where i cant do anything unless i can force software onto the box as they are both dead. do you load the BG_LOGO file the same way as the firmware using a usb stick?
    WARNING DO NOT TAKE USB OUT OF BOX WHEN SWITCHED ON brick ya box
  4. #79
    Dec 2008
    stockport
    [quote=gerald5445;394002]
    Quote Originally Posted by garyb View Post
    thanks jok
    not sure what you are on about basically but your last comment about "not taking usb stick out when switched on" means just that!! do not or you WILL brick it. assume you have done so!!
    YNWA..
  5. #80
    Aug 2009
    can anyone that has successfully repaired a starview4 8882 with a usb to rs232 adapter please post a link to all the hardware u used thanks
  6. #81
    Feb 2009
    Birmingham
    Quote Originally Posted by wahooo View Post
    From tailor made circuits & will come with a disc containing relevant instructions
    starview usb/Pansat 8882 fix max232
  7. #82
    Aug 2009
    i have already got this but it doesn't seem to work on any computer. what i meant was the cables in-between the pc and box preferably someone who has used a usb to serial and any other cables to say where the got them from.
  8. #83
    Sep 2008
    be aware there may be 2 different cables ,a serial cable that has got parallel wires and a null modem cable which has a crossover wire for flashing.people get wrong cables and you cant flash with them.
  9. #84
    Jun 2010
    Quote Originally Posted by satsmo View Post
    There are quite a few threads on it and where to get the Max232 interface.
    First port of call should be your supplier, most decent suppliers will swap it and replace it for you.
    will this work on 8882 error on starview 4 box?
  10. #85
    Jan 2009
    Quote Originally Posted by batamiz View Post
    yes mate it will.
