Results 1 to 3 of 3
    V.I.P. Member opsmonkey's Avatar
    Nov 2008
    var/etc
    Default Enter Keys Manually On Dreambox
    Here is how to enter keys manually onto dreambox's for those not set up via pc ect.
    It is assumed that you know your provider and know the latest keys. Also untested on cable box as I only have sat.
    Push the yellow button on remote.
    Select Tuxbox commander
    Scroll down to var, then press ok.
    Scroll down to keys, then press ok
    Scroll down to softcamkeys. Make sure its highlighted.
    Press 4 or whichever option says edit.
    Scroll down to the line under encrtyptions (nagra for cable) that is your providers id.
    Push ok on the line you require. This will highlight the line.
    Use left or right to move along the line.
    Use the number keys on the remote to edit the number and alpha's
    When done exit out.
    Save alterations and exit further out and restart the cam.
    Hopefully the screen will clear.
    Should help those without internet connection
    Is there any image already equipped with TuxBox Commander that works on DM500? I am asking because my ASIX controller is dead, so any interaction/download via eth is not an option.
    I have to enter keys via remote controller manually, so I can use this box as much as I can.
    Thanx man..
