Results 1 to 3 of 3
    yellowstilo's Avatar
    Default trouble with writing speed Magpro2 / IAW5NFT1
    i just received my clone Magpro2 and tried it on a Fiat Stilo i.6 IAW5NFT1 ecu - it reads ok. using the standard set max. speed but fails to write on all available speeds - writing speed not supported for this ecu??
    Does someone have experience with writing 5NFT ecu's with Magpro??
    Thank you for your help!
    Junior Member clio_williams's Avatar
    Turkey
    i had same problem once upon a time, also reading time is too long and writing to that sort of ecu is impossible. only way out to perform it is to get a marelli iaw decoder))
    DK Veteran rappttor's Avatar
    PERPETUUM MOBILE
    i have one on my table, bricked by someone who tried to write it with galetto; the prolem was that it said cks incorect and stoped at 99%.
    never could make it work again, and the proc inside is from the first generation of bga, micromotorola.
    never manage to remake it. take care with it, its a little bitc..h.
    there has to be a way to put it in boot mode, but never find it.
