Page 2 of 4 FirstFirst 1234 LastLast
Results 16 to 30 of 52
  1. #16
    MACEDONIA
    look hire
  2. The Following User Says Thank You to whiskymk For This Useful Post:
    brchip (8th April, 2013)
  3. #17
    dijo's Avatar
    Quote Originally Posted by brchip View Post
    No, this is from the immo box eprom 93c56. Alfa 156 2.0 TS 1999.
    Attachment 191161
    Ok, as I told you= 256bytes!
  4. #18
    Quote Originally Posted by whiskymk View Post
    look hire
    Thank you mate, 2 of them were correct! But the 47267 PIN didn't work, could you try it again? I'm including another one, last one. Thank YOUUUUU!
  5. #19
    look hire
    Please forget last post, I think I got a wrong reading.
    The 47267 PIN didn't work, could you try it again? I'm including another one, last one. Thank YOUUUUU!
  6. #20
    dijo's Avatar
    LOGIN: 064719
  7. The Following User Says Thank You to dijo For This Useful Post:
  8. #21
    Quote Originally Posted by dijo View Post
    LOGIN: 064719
    Thank you! Login works!
    Could you see if you can find the login for these files?
    Thanks again!
  9. #22
    dijo's Avatar
    Thanks again!
    sorry, cant open it (corrupt?)
  10. The Following User Says Thank You to dijo For This Useful Post:
    brchip (11th April, 2013)
  11. #23
    Uploaded again.
  12. #24
    richard27's Avatar
    Aug 2011
    you pin: 47267
    ​information sharing
  13. The Following User Says Thank You to richard27 For This Useful Post:
  14. #25
    topclef's Avatar
    Login : 47267
    Sent from my Nokia 3310 using Astra 23,5?E
    you have two choices in the morning: go back to bed and continue dreaming, or you get up to make your dreams come true
  15. The Following User Says Thank You to topclef For This Useful Post:
  16. #26
    Hello again, need PIN from this dump, Alfa 156 2.0 1999 immo 93c56. I read it twice, first as 8 bits and then with 16 bits. Which one is correct??
    Thanks in advance!
  17. #27
    electrones's Avatar
    Feb 2012
    Around C.V
    Thanks in advance!
    Hi friend
    Pin - 31439
    With 16bits
    Good luck, ^_^
    Press "THANKS" button. just one click, CHEERS
  18. The Following User Says Thank You to electrones For This Useful Post:
    brchip (16th May, 2013)
  19. #28
    Quote Originally Posted by electrones View Post
    Hi friend
    Pin - 31439
    With 16bits
    Good luck, ^_^
    Thank you m8! Will test and report. So, 16 bits it is.
  20. #29
    Hi friend
    Pin - 31439
    With 16bits
    Good luck, ^_^
    Tested and working! Thank you.
  21. #30
    please calculate pin for me
