yellowstilo (19th April, 2021)
Reality of life :
1:Never argue with an idiot, he will pull you down to his level and overcome you with experience
2:Envy is the confession of inferiority
3:Everyone lies
How much trash you leave behind so much trash someone will have to read or maybe you yourself
If you like reading garbage, don't slow down, just speed it up
yes you're probably right but i always want to understand how things work, just picking a ready solution is not very satifying....
So i will give it a try, will post my findings if i found the pin algo !
Reality of life :
3:Everyone lies
you mean you know how the pin is decrypted from the file ?
Reality of life :
3:Everyone lies
i did try to login with pincode with 2 different files and programmed transponders but still no joy, the Examiner Smart does not accept the pincodes....
To be continued....
i finally managed to login with the pincode using the Examiner Smart HD tester - i used a 93c56 file from DK with PIN 55292 but i had to flip the bytes of the entire file before the tester accepted it - in the "normal" way it produced a lot of unreadable garbage info .
It was also strange to see the pincode did not change although the bytes were moved to other locations so i guess it will be some sum calculation of a fixed part of the file where the byte order is not important ....
kiszka (20th April, 2021)
