Results 1 to 10 of 10
    Feb 2010
    Angry VAG K+CAN USB Help
    Guys, i hve this 1.4 Vag k Can commander(china). it always worked fine.
    Today i tried to use it..and detects it as Ross Tech Direct USB interface. as a USB port.
    I need it back to LPT and COM ports section under device manager, so i can adjust the COM settings to match the software.
    What hs happened to it? why now it detects it as USB? instead of COM? i tried reinstalling it..and various FTDi drivers...no luck
    Dec 2010
    Ro
    try another interface on the same laptop.
    Feb 2010
    i tried on 5 PCs, i managed to reprogram the Eeprom thanks to my old friend ipejasinovic, i ll check tomorrow and let everyone else know.
    thanks ipejasinovic
    Feb 2010
    Done, perfect works 100%
    Mar 2011
    Oradea
    how you get rewrite the eeprom, you got removed from pcb?
    DK Veteran zeljolaki's Avatar
    Nov 2009
    In my garage
    Quote Originally Posted by Djice View Post
    No, dont need ,MProg is your frend: FTDI Utilities
    Feb 2010
    downloaded FT prog from there, and used a backup template. i cant seem to find it right now. But it can be done in 5 min with Ft prog, no need to desolder or open anything
    Jun 2012
    i have the same situation
    could you make a tuto or place some pics to know how to fix it
    Feb 2011
    france*
    hi
    i have same problem with the interface vagkcan 1.4...i think the car is not compatible...
    Mar 2011
    Oradea
    Finaly I repaired with modify some driver files and rewrite, I makit a 2.5 cable with rewrite.
