I am not sure but may be ddt2000 on k line
Its on the forum somewhere
Good luck
Car is Megane from 2003 1.9dci
I have galletto, mpps, magpro2 but nobody cannot read flash from via OBD.
Galleto cannot change speed, mpps cant read edc16 from renault, magpro2 cannot recognize ecu...
ECU is repaired by me few times, (somebody after me overheated and destroyed some lines on PCB) now need to be reflashed with original dump and need to try remove EGR from flash.
Now I cannot open ECU because somebody used strong dual component glue, so only way is to try via OBD or to try connect to ECU pins?
Any suggestion?
Good luck
[I]Automotive Electronics Solutions
Mercedes-Benz Reverse Development Engineer ...
Mercedes CFF 2010-2017 CFF all models all modules
Vediamo help flashing over teamviewer ...
JLR SDD online + offline ...last official ...
Galleto reflash only tuning part of the prom
Reflash all the prom only with DDT2000 or CAN-Clip sonde.
I should put another new dump, not orginal renault. I have reprog CD but where is option in renault clip for reprogram. Do I need any password.
Can somebody post reprog cd on megaupload please?
Renault Can-Clip reprog v96 :
Try this link, is on megaupload or rapidshare
clip reprog - Renault REPROG v.96.0
Mpps 5.xxx now have support for this EDC16C3 and EDC16CP33, i tested it today. I got ID, all nozzle codes OK, but when start reading, have long wait and message to contact amt.
use BDM far better on those renaults
i tried to make it work once over obd, i bricked it
I read edc16 only with bdm
this is the safest method of reading
best regards
After researching and few experiments, finally did it via OBD, just removed few fuses which probably blocking communication via K line.
