Results 1 to 13 of 13
    Jan 2011
    Ukraine
    Default Kawasaki ZX-6R add key
    Please hint to PM cryptokey for bike
    Ecu denso 21175-0109
    eep 93c66
    Regards StasAV
    gepakg's Avatar
    Serbia
    ok,now in dump one master(red) and 2 slave (black) keys
    you have an original kawasaki key and read it TIRIS format whit any tool a will add it for you
    regards Gepa
    Quote Originally Posted by StasaV View Post
    eep 93c66
    Regards StasAV
    Jan 2011
    Ukraine
    Quote Originally Posted by gepakg View Post
    regards Gepa
    I have not original kawasaki key
    if have the original key, it is enough to enter the ID + ID inversion.
    gepakg's Avatar
    Serbia
    no,on page4 from 4d transponder kawasaki have secret key what is exactly need to be recognized from ECU!
    regards Gepa
    Jan 2011
    Ukraine
    regards Gepa
    Cryptokey not in dump
    Cryptokey is standart for Kawasaki
    gepakg's Avatar
    Serbia
    crypto key not in dump extracted with algo from serial id of transponder,but also this algo in mcu of ecu...
    anyway didnt work if page4 isnt kawsaki crypto key...not possible to rewrite only ID + inverse...
    regards Gepa
    london
    think u should have read as 8 bit
    keys are on line 120
    if is 8 bit then line 90
    sure is 8 bit
    gepakg's Avatar
    Serbia
    dump is correct,3 keys very visiable,he have problem to make original kawasaki transponder,tmpro have module for it!
    regards Gepa
    Quote Originally Posted by ecu-master View Post
    sure is 8 bit
    gojko's Avatar
    Vrsac
    Is it possible to copy the 93c66 and the key of the second motorcycle and copied to the
    gepakg's Avatar
    Serbia
    yes,possible
    regards Gepa
    Quote Originally Posted by gojko View Post
    HeXeN's Avatar
    Mar 2015
    Do you have a pic where to cut a hole ?
    Stelaras26's Avatar
    Nov 2017
    Skyrim
    Bump,i need a pic of where the eeprom is too
    If i Helped you,use thanks and rep button to thank me back
  13. #13
    Stelaras26's Avatar
    Nov 2017
    Skyrim
    Never mind i found it via tmpro pics.bottom left is the one
