Results 1 to 10 of 10
    Jun 2011
    Default H O N D A airbag
    I need to repair this dump.
    The unit dont shows errors on diag, but light goes ON.
    Whe turn off the light, but she goes ON after a while.
    77960-S04-G83
    24c01 smd 8pin inside
    Br
    Mike2011
    Hi, The problem is solved now, The flex of drive was broken.
    Many thanks to all.
    Br
    Mike2011
    Mar 2010
    Try to short pins 4,5 and 9 on OBD connector and read blink codes
    Jun 2011
    Default obd
    Thanks for reply,
    This car Honda Civic ... year 96, dont have obd PLUG.
    The diag blink codes is on other plug, yellow, but dont make blink codes, only goes on and off.... and sometimes the car work fine, led off,... and the after a minute....hour, or a day
    the light turns on again, and we need to reset.
    If you have solution, or a good dump, please post.
    Br
    Mike2011
    Quote Originally Posted by randewoo View Post
    DK Veteran kasim_izmir's Avatar
    turkey / izmir
    Quote Originally Posted by mike2011 View Post
    77960-S04-G83
    Br
    Mike2011
    Hi , this dump is good
    i tested myself
    good luck
    Jun 2011
    ok, I will try ans post result.
    Many thanks for try to help.
    BR
    Mike2011
    martij976's Avatar
    Jul 2010
    Thanks for reply,
    Br
    Mike2011
    Yellow plug is for resseting. For blink codes need bypass gray plug located near the ECU under right kick panel.
    Jan 2011
    i think the ecu has low voltage , check battery or charge system,
    Feb 2010
    ...where was Columbus
    fist of all, from 96 and up the OBD 2 plug is mundatory. so try to find that plug. if no codes on SRS system but SRS lights ON just check the charge system for over voltage issue. 15.2 volt is a threshold level for this problem on many Honda's SRS system. If some codes like 8-2 --8-6 but I'm not sure because I don't remember exactly, the problem is a capacitors shrinks its volume because a time. just change the biggest capacitor inside the SRS module will fix that problem.
    shumo7722
    Guest
    i know your problem, first the airbags on these cars will go off if the voltage goes aboe 15.2 on the battery. check your voltage, if it goes above that your alternator is bad.
    Jun 2011
    Default Solved
    The problem was in driver flex, sometimes when turns the light goes ON.
    I change, It's Ok now.
    Thanks to all who try to help.
    The original dump was OK, so the problem was hardware.
    Br
    Mike2011
