Results 1 to 15 of 15
    diagnoza_auto2000's Avatar
    Jul 2010
    Sibiu
    Default toyota corolla dumps immo+ecu,key lost
    Hello evryone,i have a problem with a client.
    He lost all keys from his Corolla 2003.
    Diesel engine ecu DENSO 89661-13060 with 93c56 and immo box Tokay Rika with 93lc66.
    I try to make keys by adding tiris 4C data into immo file,security led go off but car not start.
    I try to put virgin dump in immo ,put in learning mode add 3 key 4C,security led go off with all 3 but car not start.
    I think i must merry ecu with immo,this is why i ask a pair of dumps,or any ideea.
    Thanks a lot for who give me a help !
    Dec 2010
    Default hi
    try this file
    When security led go off, just make igntion on and make bridge between 4 and 13 PIN in obd2 socket for 31min. After this time ignition off, bridge out. It make synchronization between ECU and IMMO in all Toyota and Lexus car till 2008/2010.
    Nov 2009
    Chile
    Quote Originally Posted by diagnoza_auto2000 View Post
    friend upload both dump for help you
    Are you using ceramic or glass 4C chip?
    Jul 2010
    Sibiu
    Quote Originally Posted by autofan1965 View Post
    I have try this too,2 times.Same think .
    Jul 2010
    Sibiu
    Quote Originally Posted by LATTINO View Post
    I use ceramic chip 4C.
    Last week i have another corolla with bosch ecu and same immo tokay rika and car start very easy after add keys.
    This one with denso ecu its little dificult as i see.
    Thank you all
    bram380's Avatar
    Aug 2009
    Indonesia +628153111774
    upload immo dump & tiris key
    Jul 2010
    Sibiu
    I upload both dump ecu+immo original.
    Can someone see if its corupted?
    Tiris format
    7E FC E8 C3 09 00 00 00 00 E7 DE 7E 00 00
  9. The Following User Says Thank You to diagnoza_auto2000 For This Useful Post:
    PowerCheck (28th November, 2021)
  10. #9
    bram380's Avatar
    Aug 2009
    try this dump:
  11. #10
    Jul 2010
    Sibiu
    I wil try monday i will report.
    Do you have a virgin dump for ECU too?
    Thank you
  12. #11
    Jul 2010
    Sibiu
    I test but car not start,any new ideeas?
    Anyone have virgin dump for ecu?Or a pair dumps?
    Thank you
  13. #12
    keygargoil's Avatar
    May 2010
    i have the same problem but mine wasnt keys lost its a engine start blocked by immobiliser but immo light goes out any ideas
  14. #13
    Jul 2010
    Sibiu
    Nowbody have pair dumps for my corolla?
    Or virgin dumps?
    Thank you
  15. #14
    Jul 2010
    Sibiu
    Probem still not solved,client don t want to take the car to the dealer,and ask me for a solution.
    I add 3 keys Security led go off,but i don t know how to edit dump to be syncro with immobox,
    I try bridge 13 and 4 many many times,not work.
    I read DTC:
    Immobilizer malfunctions
    How to allign this 2 units?
  16. #15
    Dec 2011
    hi did you resolve the car problem?? i have same problem with corola. is possible you send me the bin ecu and immo and the key . i need see how can ia add the key and how can sycr the immo and ecu. thanks you
