Results 1 to 15 of 30
    Oct 2010
    Default Dreambox not starting up?
    I'm currently having a problem with my dreambox, it was working fine before and it said tune failed, i took the power cord out and now when I'm re-inserting it, nothing happens, there isn't anything on the screen or on the OLED display.
    How do I solve this?
    Thanks.
    V.I.P. Member andy91's Avatar
    Aug 2010
    East Midlands
    Quote Originally Posted by irsh12 View Post
    Thanks.
    They do that now and then just keep putting the power in and out quickly.
    Think its a way to stop you crashing the box.
    Andy.
    Oct 2010
    Quote Originally Posted by andy91 View Post
    Andy.
    I have tried that aswell, still nothing, any ideas? Just to confirm, I am meant to plug it in then take it out quickly, would that not damage the box?
    THanks.
    Aug 2010
    East Midlands
    THanks.
    In and out and back in again for me.
    Happened to me when i first got my box last year and i thought it was shagged.
    Have to remember these linux boxes are a bit flakey.
    Andy.
    Oct 2010
    Andy.
    Just tried that aswell still nothing, is it possible to check something inside?
    Thanks again.
    satsmo's Avatar
    Jun 2008
    The tuner could be loose and would give this symptom also. Take of the back plate, slide out the tuner and re-insert it.
    Power back up the box to test and it should work. Power down again put back plate on and power back on.
    I refuse to answer that question on the grounds that I don't know the answer. - Douglas Adams
    Oct 2010
    Quote Originally Posted by satsmo View Post
    Just tried that, still nothing in the display. Any other ideas?
    Oct 2010
    I tried powering it on with the tuner out still nothing.
    Aug 2010
    East Midlands
    Dont suppose you have a another Psu?
    Andy.
    satsmo's Avatar
    Jun 2008
    You need to remove the tuner and replace it back in it's slot and then power up. Are there any signs of life at the back of the box, i.e. the ethernet port LEDs?
    Other than that try Dreamup and see if that can see the box.
    Oct 2010
    Andy.
    I tried a different psu, still doesn't work
    Oct 2010
    I tried the dreamup, it doesn't see it, the LED's of the ethernet doesn't light up.
  13. #13
    satsmo's Avatar
    Jun 2008
    Could be the PSU as Andy says sorry.
  14. #14
    Aug 2010
    East Midlands
    Was going to say that wont it connect to Dreamup,doesnt sound good does it?
    Think i would wait till it cools down and try again.
    Where did you buy it from?
    Andy.
  15. #15
    Oct 2010
    Andy.
    From aliexpress in HK, I purchased 1 already before and it's still working fine. I've compared this one to the one I have already and it looks nothing similar, on the tuner it says MIDE instead of MADE.
    Also, am I corrent to say the box wouldn't boot up without a tuner?
    Thanks.
