Just tried it again, still nothing coming up, is there something I can replace inside the box that's gone wrong?
Thanks.
I had exactly the same problem. Check for some slight melting around the power connector on the back of the box.
I was trying out some images when then I got Tuner Failed and then the Motherboard died. When I looked inside there was a dark patch around the PSU connector on the motherboard. There should be a light on the PSU brick which should indicate that its OK and giving power. When the box is turned on the Ethernet light should come on blinking. If not I'm afraid the board may have fried.
Some pics here http://www.digital-kaos.co.uk/forums...oblems-207466/
I bought a new board from my seller. You could try an exchange under warranty. Thats what Satsmo advised me.
I normally flash through Dreamup but when this happened I was flashing through the Web Interface. In doing so I unplugged and replugged a few times to enter the second stage bootup process. I cant be sure but I think this may have caused some sort of surge to my motherboard. But that does not explain the Tuner Faild just before it dying.
With a new motherboard my box is fine now, so Tuner and PSU where not faulty.
Just hopes this helps your troubleshooting.
Hi, thanks alot for replying. I had the same problem, tuner failed before I unplugged the power. I also flashed through the web interface. Is the motherboard hard to replace, how can I get one in the UK, I don't want to send this one back to HK as it will cost alot of money.
Hope to hear from you soon.
Thanks again.
The motherboard is simple to replace.
If it is gone, I paid 80 euro for mine. I didn't send my old board back because I just wanted the football back on asap as the season was coming to an end. Now I wish I returned my old board as the new one took only about 9 days with HK post with which the tracking of it was very good.
I'm nearly sure most of these boxes come from the same business district in china and they are not that bad to deal with. In saying that if you send an email one day they will answer it during the night and you will recieve it the next day and so on. This can be a problem sometimes when you're asking simple questions due to the language barrier.
I hope your box comes back to life but if I was you and it is the board that's gone. I'd tell your seller the motherboard has failed and if you sent it (the motherboard) back would he replace it.
Or you could ask how much for a new motherboard in euro or pounds including delivery, Thats what I did to my seller here: Contact Us : Dreambox.me.uk, Best Prices on Dreambox and CCTV
The new board I got was a new revision. Its also worth noting that a new box (incl new Rev M tuner) may be cheaper than a new motherboard & a rev M tuner.
I had the same problem just green orange network lights try booting without sim or tuner it will bott without either just showw error on display my problem was capacitors check to see if they are swollen i replaced 5 of them ?2 and all was fine again
I replaced the 4 large ones and one small one behind c112 c113 c114 c115 c249 i think the samll one is only to do with scart but was blown so i relaced it anyway I did have network light so you may need to check power supply if u have nothing
Is there a light on the PSU?
If yes then more than likely the PSU is OK.
Does the fan startup when you power on?
I cant be 100% sure but if its totally lifeless then I would definitly say its a dead motherboard. With me a new motherboard fixed it.
I would check out the warranty with your seller. Sending only the motherboard back for a new one involves less weight and maybe quicker and cheaper in both directions.
Thanks, the fan doesn't power up, it didn't power up even when it did work.
I ordered one already from the supplier and I think when I get the new one I will send the faulty one.
I didn't want to risk sending it then waiting a long time to get a new one.
I took everything apart, plugged the power into the motherboard but no light for the ethernet comes up so I take it it's dead.
I think your best option is to return it
did you try a dif power supply? and fuse in the uk converter? if you using a shaver convertor the fuse rating will be low! just an idea b4 sending it back
if it helps thanks
