Results 1 to 1 of 1
    Senior Member acestu's Avatar
    Nov 2008
    Default Jungleflasher PortIO32.sys Error Solved
    Hi Fellas,
    I have just installed the New Jungleflasher and it gave me the
    Can't load portio32.sys run as administrator ERROR
    and then it would start but not recognise any drives
    If you have this problem then try this:
    Close Jungleflasher and then
    remove any instances of
    portio32.sys from your computer from earlier installs, they are normally found in:
    c:/windows
    c:/windows/system32
    c:/windows/system32/drivers
    or just do a search for them and delete them
    Reeboot your pc
    Then open Jungleflasher again and it should work
    hope this helps someone
    cheers
    Acestu
    If my post Helps, then Please Click the THANKS Button ,as i will do for you.
    The Acestu Corporation.... More Powerfull Than You Could Possibly Imagine !!.........
