Page 70 of 70 FirstFirst ... 2060656667686970
Results 1,036 to 1,038 of 1038
  1. #1036
    May 2024
    Ys3fb49s631002956 Pin please saab 93
  2. #1037
    ...... not correct post
  3. #1038
    Jul 2024
    I need to check i have the right pin code for a SAAB 9-3 2006 VIN;YS3FB56V161030317 the PIN code i came up with was ;PIN CODE 4E44 this pin code fails to program keys with xhorse Mini obd and xhorse Key tool max i also tried Xtool D8 this also failed to Gain Access to the Saab 9-3 cim i think the next step will be to remove the CIM Model and EEprom 93LC66A hopefully with the Xhose Mini prog with the Pressure function with out removing the EEprom Chip off the board.
    when the Saab 9-3 was scaned for fault codes and found these codes BCM Model B2991 B0092 B0092 CIM Module B3060 B3935 B3981 REC Rear Electical Center Fault codes B2545 B3883 the Battery was in a poor state when tested so all caused problems that could stop the new keys being programmed Evern with Tech2 softwear so wasted a lot of time on this the only thing possible is to Clone the Orignal Key ID46 chip with Xhorsee X27 SUPER CHIP this worked and was able to place the Cloned Chip in a SAAB 9-3 repair case and was able to start the car but had no remote function in the cloned key but able to Access the car with the WT47 KEY BLADE so Xhorse Key tool Max got me out of trouble
