Results 1 to 5 of 5
    Default Help with Tuner settings
    Hi, I'm running Vix 2.2 image
    What are the correct tuner settings for a fixed dish with dual LNB
    separate cable to each tuner.
    I have Tuner A and B set at Simple, single, 28e and No,
    when I go to autoscan I am only ever given the option to scan tuner A, never tuner B
    thanks for any help.
    Apr 2008
    Can you watch one programme while recording another. If you can why worry. If you want to complicate things you can have both on advance setttings, and set them up as independant inputs, but there will be no advantage, if it is a dual LNB.
    V.I.P. Member dell_xps's Avatar
    You only need to scan Tuner A :-)
    Sep 2010
    as dell_xps say's you only need to scan the one tuner.
    Smile Thanks for the help
    Thanks to everyone who replied,
    I have now sorted it, just scanned tuner A as suggested.
    The Vu+ Duo is a great piece of kit.
