Page 4 of 4 FirstFirst 1234
Results 46 to 59 of 59
  1. #46
    DK Veteran cocoh's Avatar
    Jun 2009
    [quote=impactops;1221865][quote=cocoh;1221212]
    Quote Originally Posted by impactops View Post
    Picture's don't mean shit captain!!
    Your colleague shows them each time there is a new version, but no solution!!!.He's missing the "Smart" folder off the F:\ drive, you on the other hand have copied everything off the disk to fill the void!!!.So yes you will get it working that way.
    You have never contributed anything useful to the forum other than teasing people by showing them something they will never get from you, for that i would of banned you along time ago.People are not stupid cocoh, if you have it working why don't you release it on your bosses forum with your other alias like it has been promised to them or are you waiting to see if someone else posts one so that if they don't you can sell it? Thats what the forum is about to help people right?
    Does it come with a Super Supreme Free Bonus with a Cherry on top?
    Impactops
    this time I tell you... NO COMMENTS Mr. Impactops...!!!
    Its important that its work well..
    No matter how I did it...
    have a nice day... and
  2. #47
    impactops's Avatar
    What happend you didn't like the response!
    The truth hurts?
    Until someone comes up with something better...
    Then you decide to use it and thank those you were gloating too prior to there solution being released.
    Impactops
  3. #48
    Default Cocoh - man :-(
    The truth hurts?
    Impactops
    This days I've received a proposition from him , he wanted 50 euro.....
    Every day, every hour I like. Still alive.
  4. #49
    Jun 2009
    Quote Originally Posted by CarmasterAndrew View Post
    CAN you write here... (the email) in this case ALL PERSON CAN SEE that EMAIL??? WHO ASKED YOU FOR 50 euro to have this FIX???
    PLEASE.. go ahead.. write here the email...
    and remember... who asked you 50 euro for this fix... he worked hard... you looking always for FREE..
    You are flying from forum to forum to get THIS FIX for free... and you are bombarding people with messages to help you...
    THIS YOU ARE...
    Why don't you ask at YOUR BOSS Mr. Patrian???????? seems this time LEFT YOU alone...
    have a nice day..
  5. #50
    Default 50 EURO
    Quote Originally Posted by cocoh View Post
    THIS YOU ARE...
    have a nice day..
    Ofcoz the e-mail I received not from Cocoh .. ^-)
    But I can show personal messages container where you wrote something... You want to keep your face clean? The easist way is to be clean man . If you can help - just do it....
    Regards!!!
  6. #51
    Default .... continued
    THIS YOU ARE...
    have a nice day..[/QUOTE]
    ... also I want you to know... I am not seller of the others work. I just looking for free , coz have enough ?. But some of the DK members do just for ?.... So what is better or what is the worse - to be lokking free solutioons and just USE them or to be hidden resellers? A?
  7. #52
    Oct 2010
    Odense
    Installed 07-2011 on Dell d630 en HP, both with native serial port. Faced some probs as mentioned in this thread.
    Some tips:
    - Replace the Commonlic.dll in C:\Documents and Settings\owner\Local Settings\Temp\{6E8BCD31-9798-4A4B-94C4-55DD941952E5} \{22A937EF-8C64-11D7-A9EE-00D009D07BEF}.
    - You will probably get an error with APPID / License is not correct. At that point, replace the dll again and ignore this error
    - Change my computer name with a name listed in C:\Documents and Settings\owner\Local Settings\Temp\{6E8BCD31-9798-4A4B-94C4-55DD941952E5}\{22A937EF-8C64-11D7-A9EE-00D009D07BEF}/kundendaten
    - adapted version.txt in dasunst and enabled das lizenz und wis lizenz
    - Afterswards, enabled SDI (fix did not work) by
    sc create SDImpersonationService binpath= c:\winxp\zak\service.exe
    otherwise SDNC.exe does not work and Xentry will not startup (gives a 2200 error or something like that)
    Good luck
  8. #53
    Hi Cocoh, can you share us the commonlic.dll= 272 kb that you used for the installation?? Can you specify where you replaced this file?? thanks
  9. #54
    Quote Originally Posted by ddam81 View Post
    If you do need to ask this, then you should actually use the new zolookas guide for 2011. Available from this forum. Then you do not need to worry about the file and where to put it.
  10. #55
    Hi DB_member, I know about zolookas guide but I'm installing the 07/2011 version and it give me ever this error of the version information!! Then I need your help to install DAS fine!!
    Could you post me full istruction to update it from 03/2011 to 07/2011 please?? Thank you
  11. #56
    There is NEW guide - check forum....
  12. #57
    OK, then I explain you my problems:
    I must only update the system from 03/2011 to 07/2011.
    I have follow your guide, but it give me error on Xentry ID and I have replaced the file CommonLic.dll (file that you share compress named CommonLic_07.rar) into C:\....\Temp\(and strange folder)
    It go next and give me partition problem, and I go next closing the error page through TaskManager, but after the "...the system are writing the icon..." it give me the famous error!!!
    Now how I can install it??
    Please help me
    PS. when I load your prepare.bat, when it must close the SD Impersonation, it say it's impossible close it!!! Is it the problem?
  13. #58
    impactops's Avatar
    @ddam81
    People have already suggested to you what to do, but you keep insisting.Download & read the guide below.It is an automated process.If you have read any of the threads you would of known that it has been suggested that a clean install is best.So try the guide first
    http://www.digital-kaos.co.uk/forums...2011-a-226318/
    Impactops
  14. #59
    Thank you for your reply, I'm just installed all very good before look your reply!!!!
    Best Regards
