Results 1 to 9 of 9
    puiu's Avatar
    Timisoara
    Default Audi Q7 4.2 new used ECU learning help urgent
    i need help with the learning of bothh ECU ,master and slave
    from an Q7 4.2 with EDC16CP34
    i changed the both ECU software with BDM,orig data is corupted
    with VAG i entered the login pin bode accepted ,buth in chanell 50 is written Disable
    i wait 2-3 min before enter chanell 50 same message
    please i need step by step procedure,
    thank you
    You want be able to adapt it using vcds, there is adaptation with challenge. Smok, vvdi or avdi. You can try to do immo off.
    puiu's Avatar
    Timisoara
    i made immo off, but i want to learn the immo
    i will try with FVDI,
    but if someone know how to do it with VAG i still want to know how
    Nov 2010
    You cant learn immo with immo off I hope i saved you some time
    simaservis1108's Avatar
    Aug 2013
    Serbia,Belgrade
    Why go thru all that hassle?
    Full BDM copy,and job done in maybe 1hr.
  6. The Following User Says Thank You to simaservis1108 For This Useful Post:
    Fallen (17th October, 2015)
  7. #6
    Siham's Avatar
    Jul 2014
    Quote Originally Posted by simaservis1108 View Post
    What to do when original data are corrupted??
    No thank , no HELP .
  8. #7
    puiu's Avatar
    Timisoara
    original data is tuned by ABT and after that some genie has remowed with ECUsafe, I suppose ,DPF and now data is corupted and useless
  9. #8
    Aug 2013
    Serbia,Belgrade
    Write flash from new to used and car should start if eeprom is untouched
  10. #9
    puiu's Avatar
    Timisoara
    eeprom is corupted to ,i done it like this first time ,corrected chk in eeprom ,car started and after 50 km ,stopped the car normal,and don't started again
    I checked and eeprom chk was corupted again ,I don't now what ABT is doing but i have to change the data in MCU to be able to start the car,now i think i sorted out ,i learned the immo with FVDI ,both ECU are full cloned from another working car ,tuned and dpf off ,hopefully now is all ok
    thanks for all answers ,case closed
  11. The Following User Says Thank You to puiu For This Useful Post:
    Siham (17th October, 2015)
