saxo / peugeot immo bosch ma 3.1
    Downloads
    13
    Uploads
    Default saxo / peugeot immo bosch ma 3.1
    im trying to remove the immo from a citreon saxo bosch ma 3.1 68 ecu part number 0 261 203 736 but cannot seem to read the 93cs46 chip. im using xprogm and reading the chip on the board ... the chip im trying to read is the one in the middle with these numbers on it 67ad b58 221 its the middle one of the 3 93 chips on the board.
    never done one of these ecus before and would appreciate sum help as to if its the correct chip?? well any help at all is to how to remove the immo have seen in some other threads that you can just remove this chip from the board???? is that correct??
    cheers in advance
    between cables and eeproms
    30
    Downloads
    31
    Uploads
    REMOVE and car starts but checkengine light will stay on!
    Downloads
    13
    Uploads
    so remove the 93cs46 chip the one in the middle?
    dont understand why i cant read it ???? the clip is contacted fine and if i try read another 93 chip it reads as it should ... when i read that chip it just reads blank??? any ideas?
    Top Poster + v8 dave's Avatar
    Jun 2009
    Geordieland -> Portsmouth
    Downloads
    15
    Uploads
    Sometimes they don't like to read in circuit. Rover MEMS3 ECUs have always given me trouble. You can sometimes short out the oscillator which might get them to read, but it's easier to hot air them off in the long run.
    Downloads
    13
    Uploads
    thanks for your replys i hot aired it from the board and hey presto managed to read it ... fingers xed otocheck has done the business
  6. The Following User Says Thank You to garryreed For This Useful Post:
    liban11 (12th August, 2018)
    Mar 2018
    73
    Downloads
    Uploads
    Quote Originally Posted by garryreed View Post
    can you help me with a good dump i have the same ecu need immo off
