Page 1 of 6 123456 LastLast
Results 1 to 15 of 89
    Default Peugeot 207 96 750 688 80 Bosch 0 285 010 828 crash
    hi friends
    i have crashed airbag control unit for Peugeot 207 year of product 2011 ( this control unit with plastic cover and metal base )
    i need your help clearing crash data for this unit
    Peugeot 207 2011
    Peugeot part No. 96 750 6880 80
    Bosch Part No. 0 285 010 828
    eeprom ST95160
    i attached the eeprom file
    regards
    Try this and post results .Pass is in your pm .
    regards
  3. The Following User Says Thank You to antlio For This Useful Post:
    DAVID8HENRY8 (7th December, 2016)
    Quote Originally Posted by antlio View Post
    regards
    thank you friend for your help
    but it is better if any friend has tested file because the car is far from me
    i will try and report you friend
  5. The Following User Says Thank You to naelraddad For This Useful Post:
  6. #4
    It must be ok . Test it .
    cheero's Avatar
    Czech Republic
    here is worked 100% clear, i tested 1000x
    pass in PM
    Cheero
    CHEERO
    ++++ GOOD WORK ? + ++++
    FIAT EMEA 7inch, Ford Sanyo, DELPHI Chrysler Jeep Dodge, DELPHI Volvo GMC Renault, Ford FIC, Fiat Turkey, Ford V Series Calc, Fiat Continental VP1 VP2 Calc, Opel Delco CDR500 & CDR2005 Calc, Mercedes Alpine Calc, Jaguar Alpine Calc, Fiat Daiichi Calc, Delphi Famar Fueguina Calc, Renault Calc, Dacia Calc, Grundig oldtimer Calc, Chrysler Jeep Dodge Panasonic Harman Becker Alpine Continental Calc, Blaupunkt Calc, Philips oldtimer Calc, Audi Aisin RNS-E Calc ....
  8. The Following 3 Users Say Thank You to cheero For This Useful Post:
    CarProg020 (8th June, 2015), larsen (31st July, 2013), lorexx (31st March, 2015)
  9. #6
    to my friend antlio
    after i program the chip with your file no communication with airbag ecu thanks for you help
    thank you friend cheero for your help i compared your file with the file that i have from antlio and they are the same are you sure that the file is 100% ok ?
    i tested the power lines and the ground and communication lines and they was ok ( i connected the power small connector with an older ecu and there was good communication with the scanner)
    i still need your help my friends
    regards and big thanks to all of my friends
  10. #7
    Write again the crash file in the ecu and see if you
    have communication with tester or not . If you don t
    have then the problem is in your car . Anyway my solution had work in the past many times in different ecus like yours .
  11. #8
    My friends antlio and Cheero thank you a lot for your help your files are the same and both are working 100% till now I did not understand what happened with me and what was wrong I program the control unit with antlio file and there was no communication I programmed the control unit with the file from cheero and everything was ok ( I am sure the your tow files are the same )
    i am so sorry for my mistake in work.
    really thanks
    big regards to all of my friends
  12. #9
    DK Veteran stevan's Avatar
    Bosnia
    I have same airbag for repair,if possiblle to get pass for dump?
    I have in carprog but not same number (745),ecu must be send far so can't test here.
    Tanks in advance.
  13. #10
    Bosnia
    Here dump,sorry
  14. #11
    cheero's Avatar
    Czech Republic
    here is dump for your ecu, tested and work 100%
    pass in PM
    best regards
    Cheero
    CHEERO
  15. #12
    Bosnia
    Tanks a lot pal.
  16. #13
    Quote Originally Posted by cheero View Post
    pass in PM
    Cheero
    CHEERO
    Can i have the password for the rar file please!
  17. #14
    portugal
    Default crash peugeot 207
    hi
    i have the same problem with this airbag sensor. its possible help-me ?
    many thanks
    regards
  18. #15
    cheero's Avatar
    Czech Republic
    here is 100% working clear
    best regards
    Cheero
    www.cheero.cz
