Results 1 to 8 of 8
    Bulgaria, Sofia
    Default SPRINTER 2.3 214 IMMO
    Hello, I have a problem with SPRINTER 2.3 214 IMMO TEMIC 017 545 39 32 with receiver ( 3x3 594 9611 ), box does not respond I need a working dump, the key is radio transmiter, not with a transponder , MCU mask 3D33J ( 68HC05B8 PLCC52 )
    DK Veteran chiptorque's Avatar
    Nov 2010
    hello friend, you need to burn this file and save this file to the ECU in the Eprom 24C04, so that you no longer have problems ...
    Bulgaria, Sofia
    ECU is BENZ 020 545 69 32 ,SIEMENS 5WK9 140 , PM6008 ,SW 34.95
    Quote Originally Posted by Nevidimia View Post
    You dump is correct. Problem in key.
    Open key and read EEPROM. I'll help you.
    Bulgaria, Sofia
    box does not respond on diagnosis , if the box answer ,i can test or program key ECU sai DAS inhibited.ok will open the key afternoon.
    Bulgaria, Sofia
    Dump from Key 93LC46
    Here is you key
    Bulgaria
    Hello, I have a problem with SPRINTER IMMO TEMIC 017 545 39 32 with receiver the key is radio transmiter
    I need a working dump for RF KEY- 93c46 into immo box temic
