CR or PD engine ?
Original Kwp2000+ and other...
No stress for all !
Good remap in tdi 140 and you see tdi 170 in the mirror.
Best regards
No stress for all !
i had done a few of them
In my opinion PD's will remain the most "tuneable" engines, if I may say so. Can't figure out why VAG got rid of them and switched to CR...maybe exhaust emissions too high to cope with new Euro5 regulations?
And for siemens TDI there is a few different type of ecu inside.Gain in siemens 170 is good and for CR ?
No stress for all !
There is difference in boost
Q5 2,5bar max boost
A3 2,3
Common rail injection pressures have now surpassed pd ones, look at max pressure in gen1, 2, 3, etc common rail then pd. Pds load the cam an awful lot as well. Higher pressure means better atomization better efficiency etc, thats what I think anyway.
grinovsky compare the torque/fuel at the rpm where it makes peak hp not torque, peak torque figures mean nothing re speed/acceleration, most standard diesel family saloons make a higher peak torque figure than an f1 car!
