Results 1 to 8 of 8
Hybrid View
    Jul 2009
    Default UPA USB & CR16MCS5 Problems
    Hi all
    can't seem to read a CR16MCS5
    wired up as spec sheet but was concerned with p9 red dotted wire on diagram.
    with p9 from upa connected I was getting vdd/vcc out of range...
    with p9 disconnected I was getting frame error
    took cr16 off the board now getting device not respond
    any help??????
    Cheers :-)
    DK Veteran elchip's Avatar
    Nov 2009
    EU
    Post
    Quote Originally Posted by a12arm View Post
    Hi all
    any help??????
    Cheers :-)
    Dot wire on connection mean to maybe need LIFT up pin from board ....
    [I]Automotive Electronics Solutions
    Mercedes-Benz Reverse Development Engineer ...
    Mercedes CFF 2010-2017 CFF all models all modules
    Vediamo help flashing over teamviewer ...
    JLR SDD online + offline ...last official ...
    Jul 2009
    Thanks for yhe reply I'll remember that.
    so device not responding...... could I have damaged the cr16 by not lifting the VCC pin????
    Nov 2009
    EU
    Put back MCU to board and lift pin Vdd ( Vcc ) and test again... if error lift all pins which go to upausb... and test
    Jul 2009
    Quote Originally Posted by elchip View Post
    MCU back on board lifted vcc still nothing.....
    What would the difference be programming off board to on board???
    Jul 2009
    Lithuania
    In what unit is your cr16?
