Results 1 to 8 of 8
    Default Transit pump code help
    I have been asked to help with a problem i know nothing about
    Transit fwd 02 has had a new deisel pump fitted
    The owner only has one black key
    I am told a red key is needed to code the new pump
    What is the solution?
    i am told if the pump was a recon unit it would have just learned the key
    Nov 2010
    Plymouth UK
    Default Transit pump coding
    If the pump is Bosch VP type and the vehicle has Duratorq engine then key colour has no meaning for pump programming. Using Ford IDS with either coded or timed access according to how the vehicle has previously been programmed it is possible to use the 'Body', 'Security', PATS functions to program the pump, clear the RIM and pair to the PCM ECU.
    Red coloured keys were only essential for the Lucas Epic FSD (2.5L older Transit) programming functions.
    All Duratorq engined Transit keys have a blue chip crypto and the key colour has no significance.
    Aug 2011
    Default ford
    On this auto you can make functional 100% with Autoboss v30. have special function for reset both ecm and fuel pump.
    No code need for program.
    Member trycktill's Avatar
    Dec 2010
    casablanca
    Quote Originally Posted by ciptel07 View Post
    hello sir can you explain more how to do this with autoboss v30
    thanks in advance
    Staffs UK
    "i am told if the pump was a recon unit it would have just learned the key"..... Correct re-con pump will self code
    With IDS "'Body', 'Security', PATS functions to program the pump, clear the RIM and pair to the PCM ECU."..... Correct with used OR miss-matched pump.
    Autoboss... ?
    option.... PSG5 function in Bosch KTS to make pump self code/virgin
    Read fault code in PCM for PATS fault unknown unit
    Jun 2008
    ok i am trying the same the best way without ids is too reset pump
    this is my request here
    http://www.digital-kaos.co.uk/forums...coding-237275/
    and this is what may be rquirede for way forward
    http://www.digital-kaos.co.uk/forums...0-ford-187500/
    http://www.digital-kaos.co.uk/forums...ml#post1227782
    let me know if u find something that can help me also
    if pump is reset virgin then will code itself
    just to update.
    The owners fited a new pump but the battery was flat and corrupted the self learning proceedure.
    Hope this forwarns someone.
    Good luck
    UK
    Can someone pls explain the correct procedure with autoboss v30 pls?
    if this post was usefull
    please press
    the thanks button
