Results 1 to 13 of 13
    Dec 2009
    Default honda pilot 2007 immo box
    Hello brothers, I have a 2007 honda pilot someone could tell me or is are immo box. I want to make a key for it the original key is lost
    The brothers thank you
    Nov 2009
    immo is in the ring around ignition barrel (green) why do you want to remove immo? you can use HDS.
    May 2011
    hi
    can we programm key with SBB key programmer or not ????
    thankx
    Feb 2010
    Quote Originally Posted by digimile View Post
    hi
    thankx
    Yes I think you can program with SBB clone
    Feb 2010
    Sure you can with SBB and Tcode
    Sent from iPhone 4S
    Dec 2009
    hello brother, and thank you to answer me what's the HDS?
    Dec 2009
    someone could give me the pin code is for the Honda Pilot are dump
    I think honda dont use PIN code system.
    Dec 2009
    programming key that passes without a PIN?
    Dec 2009
    the chip ID 46?
  11. #11
    Nov 2009
    you can use sbb version 33 or higher but tcode will request for incode, HDS is Honda Diagnostics System and china has a 100% working clone called Fly 100 which is about $250
  12. #12
    Feb 2010
    use SBB without pin code
  13. #13
    Dec 2009
    The brothers thank you for your answer
