Results 1 to 8 of 8
Hybrid View
    Default pin code from vw passat
    hi,
    please help me with the pin for VW Passat 2006 and Audi A4 1997, the new key adaptation
    Jun 2009
    for both it's better to read eeproms from ecu's and send dumps, you can get PIN's and make adaptations with vag com
    Maybe You can give more details next time(engine, tools what You have). But I think You can try for passat PIN can be: 6002 and for a4 7991. Remember to put 0 before when You make keys with VCDS.
    Can you tell which is the address in hex for code?
    Default Pin code audi a4 93c46
    this code don't work: 7991.
    please help me with pin code from audi a4, 1997, 93C46
    Quote Originally Posted by mobel View Post
    if this immobox dump i think your dump is damaged,try read once again
    Sorry for bad english
    engvitinho's Avatar
    EU
    try 9719
    regards
    Apr 2011
    in lebanon
    Hi, is this immobox dump? login 04182.
