is from ecu air bag vag
Im having the same problem with UPA and Xprog
Oj38m from Ford Ka 2003
any idea ?
hello.you check oscilator frequency????
regards
Yes i dis now i see one comp is missing on the board ,
do you have a pict of it ?
I am here: http://tapatalk.com/map.php?4nmeqp
i read it when i lift pins BKGD and reset
ok i will try but do you have a pic of the board bcs one comp is missing on the board on my ecu just to check
I am here: http://tapatalk.com/map.php?nxlnyx
connect to vddx and vssx instead of vdd and vss
NEVER GET SO BUSY MAKING A LIVING THAT YOU FORGET TO MAKE A LIFE......
ETL programmer don't seem to read this too!
