hi , please can sene me the password , thank you
pass please
Hi,I have a faulty ecu after reprograming.I need dump for:
6s61-12a650-nb (flash & eprom)
s118763015b SIM21 2DTB
Ford fiesta 1,3
Thanks in advance
pass bitte..danke
4S61-12A650-KB J38AC S118763006 9ANB
Hi mates,
I need flash and eeprom dump for 2S6A-12A650-NB 1THA SIM21 ECU for FORD Fiesta 2004 1,3 petrol.
I have car with broken ECU after accident (PCB smashed and eeprom missing). Changed ECU to 3NUC and learned keys with IDS. Everything worked perfect for 2 days. Then Speedometer stoped. ABS, IC, PCM have no DTCs. ABS reads speed on all 4 wheels but doesn't send it further. PCM and IC shows 0 km/h.
I think problem is in PCM configuration.
Maybe anyone can help me?
OK I fixed it
I told IDS when it asked me if data about car read from PCM is correct that is not he asked me what is real number of PCM and he flashed me PCM with correct dump and all info for speedometer Then I learned keys and everything works great
Maybe someone samoday will need to use this way... now you now it works
Cheers
hello friend!
the problem is similar
ids can't solve it!
maybe original eprom flash pair?
This car has no abs and no air conditioning
original controller number: 6s61-12a650 pb 3EAB SIM21
THANK YOU
