Results 1 to 4 of 4
    Timisoara
    Default C4 wireless multiplexer
    Hello
    I have a problem setting the mux to worck in wireless mode
    SDnet control connect to the head via cable but no way to do it via wireless
    I try all the options that SDnetAssist offer
    i even change the SSID name and set a different password
    i can connectet to mux i can ping the ip address of the mux but on the dipsay of the mux there is no wireless mode and menu options are missing
    Whren i press the service key pad there is is only
    Restart
    Powerdown and
    Delete configuration
    in the info key pad
    Car battery voltage
    Name
    Serial Nr
    Os
    CSD
    IP address
    WLanMAC
    Is there a way to connect to the head via web interface like ICOM and edit configuration from there ?
    Or is thre an PIC or eeprom and the possibility that information get corrupted ? if yes then please if somebody have a dump please share with me
    thank you
    Timisoara
    Come one no body can give a hint
    cipijoint's Avatar
    your C4 its original,so then you have problem with wireless.
    in china will be released also C4 in few weeks.
    If eeprom from star licence inside not good, then via cable will not diagnostic at all
    ,so if via cable work, then wireless not good
    dont talk a lot and nothing
    Timisoara
    Problem solved with a full software update
