Results 1 to 14 of 14
Thread: EPG
    Apr 2011
    Default EPG
    Got my DM800 up and running but not really happy about the EPG, tried the cool tv guide but not much difference really, is there an alternative out there that will give me a 7 day epg??
    V.I.P. Member andy91's Avatar
    Aug 2010
    East Midlands
    Depends on what image your using Rytec SkyUK is the best and most stable,Satmate is also ok.
    Andy.
    Junior Member redone's Avatar
    Jan 2010
    North West is best!!
    crossepg is very good m8.
    Downloadable via tunisiasat
    Nov 2008
    yes, depends on which image you are running.
    all the mentioned ones are good and provide 7 days epg.
    quiet simple to install as well.
    DK Veteran Rodbouy's Avatar
    Jul 2010
    I use Rytec also and works a treat.
    Apr 2011
    thanks chaps, what else do i need to do to enhance this little bundle of joy i have.....this is what i have got installed and if you think i am missing something or i should have or no about please let me know.
    Db800 pro hd
    250gb hdd installed and setup for pause/rewind/record ect
    a decent sub for it and a really good reception
    cross epg installed and rtyec
    bouqets sorted
    usb cooling fan for it
    anything else i should need ??
    cheers
    Member rudy691's Avatar
    Oct 2010
    i've put this image on my dm800hd
    Digital Kaos - Downloads - newnigma2-exp-dm800-ssl82.rar
    how can i get the rytec epg on this ?
    Apr 2011
    Hi Mate..i have the BH phoenix image, you need to press the blue button, red button for epg settings and then download the rytec skyuk, also you can access the TS panel>addons and downlod the crossepg.
    not sure if it will be the same method on your image??
    Quote Originally Posted by rudy691 View Post
    Oct 2010
    will give it a go, when i come back from work managed to recover my dm after no ca error today
    Nov 2008
    well done.....i had same problem as well couple of days back.
  11. #11
    Oct 2010
    it gave me a bit of stress that 'no ca' last night but all should be ok now
  12. #12
    Nov 2008
    yeah.......i had to do a bit of searching to figure out what was happening.
    got there in the end tho........phewwwwwwwwww!!
  13. #13
    Oct 2010
    ok, ive downloaded cross epg and downloaded rytec. i did the configuration bit, but nothing is showing up really. is there some special way to turn this on ?
  14. #14
    Feb 2010
    best image for dm800 clone post on here how i got full epg just go to end post and ul see on there.
    hope it helps
