Results 1 to 12 of 12
    United Kingdom
    Default Skoda Octavia 2 ECU eeprom error
    Hi I have a ECU with EEPROM memory error on VCDS
    Here is full reading from BDM
    29BL802C
    MPC555
    E2prom
    Car start on this ECU but there is check engine ligh on
    and glow plug ligh flashing
    This is a taxi car the everything must be perfect
    I write MPC555 file but still the same
    ecu numbers:
    sw: 03G 906 016 DJ
    HW: 0 281 011 883
    DIESEL EDC16U1 6250
    810 BGP
    Address 01: Engine Labels: 03G-906-016-BKC.lbl
    Control Module Part Number: 03G 906 016 DJ
    Component and/or Version: R4 1,9L EDC G000SG 6250
    Software Coding: 0000000
    Work Shop Code: WSC 00000 000 00000
    VCID: 6ED8CCE646CD136C
    1 Fault Found
    18048 - Internal Control Module: EEPROM Error
    P1640 - 000 - -
    Freeze Frame
    RPM: 0 /min
    Torque: 0.0 Nm
    Speed: 0.0 km/h
    Bin. Bits: 10111000
    Bin. Bits: 00100000
    Bin. Bits: 00100000
    Bin. Bits: 00100000
    ALGERIA
    P1640powertrain DTC's available in an other module
    there are other module where is stored the DTC in clear
    scan the other module to find the probleme
    ecutuners's Avatar
    Apr 2011
    United Kingdom
    sounds like a immo off file strikes here
    Kess v2 FW 5.017 full unlimited token - Ktag 7.020 full unlimited token
    ALL EDC17/MED17 EEPROM CHECKSUM + VAG IMMO OFF BY EEPROM - NO SAFE
    EDC16/17 POPCORN - ME7/7.5 ANTI LAG - LAUNCH ALS/NLS
    DPF EGR DTC SCR, Custom Tuning, Damos Translation, FRF / SGO Files
    Professional Engine Software Development
    Quote Originally Posted by grinovsky View Post
    Unfortunately you are quoting Ford's explanation for the code.
    VAG (VW/Audi/Skoda/Seat) have a different description.
    See: 18048/P1640/005696 - Ross-Tech Wiki
    Like I explained in another thread, P1 codes can differ for different manufacturers.
    United Kingdom
    Hi Thank you for interest
    I've done full scan of all controllers and there is no any other problems.
    Which eeprom content is faulty? 93C56?
    Is anybody have a virgin file for this ECU?
    I don't wont to do immo off because half electronic stop working after that.
    Can I use file from other car get, immo pin and reprogram with VCDS?
    ALGERIA
    tryto programme this dump in eprom and repport
    United Kingdom
    Ok Thank you for file
    I will try tonight and let you know.
    United Kingdom
    Hi I write eeprom and plug ECU today.
    That error is clear but there is another one
    18020 - Engine Control Module Incorrectly Coded
    P1612 - 000 - - - MIL ON
    Freeze Frame
    RPM: 0 /min
    Torque: -98.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 12.92 V
    Bin. Bits: 00001100
    Bin. Bits: 0
    (no units): 0.0
    I try do do coding using VCDS 10.6 but it is no possible to change anything in ECU. I can recode any other modules but not ECU
    car start no problem, but glow plug warning light flashing.
    when I clear that fault light go off till next engine start.
    Any idea what is wrong?
    Thank you for help
    monitel_service's Avatar
    ROMANIA
    Hello
    I have your solution pls contact in privat
    wiseman's Avatar
    If your desperate to get it through a taxi test, put black tape over the lights till you figure out the problem, they will let it pass as long as they cant see the light, obviously if your desperate till it goes for its taxi test
    United Kingdom
    I solder glow plug ligh to check engine just now all looking ok, but I need to find solution to fix this problem
    ALGERIA
    you have to reprogramme the key
    or buy a new key and programme it to start engine
