Thanks for the help on this forum been taking ages to unlock my 3 Huawei modem for my Sure Jersey Sim card...
does it work with the 3565 one
Hi want to unlock e1752 from orange sim was deactivated couple of years back is this possible and couldnt gain access to unlock tool cos i have no posts perhaps I can now
A copy of the unlock calculator would be very handy about now!
Hi, could I have some direction into unlocking my modem if at all possible. I don't recognize most of the models in this thread.
I have a Vodafone Pocket WiFi 3 from Australia.
Model R205 FCC ID: QISR205 Hardware Revision: Ver.B
I have tried SBC Code Calc & Huawei MOdem Unlocker v5.8.1 with no luck. Any help appreciated.
This uses new algorithm and can not be generated by free tools!
Try here: https://www.dc-unlocker.com/supported_models_1/huawei_1
NOT free but reliable...
where is the unlocker file???
I need your help for UNLOCK my Huawei E173 Orange and take advantage of the offer of the other two operators in my country.
I have already tried several times with HUAWEI MODEM Code Writer and CardLock_UnLock but without results.
Finally I should not sold out 10 attempts for nothing
In short this can help you
IMEI: 860016012414616
Firmware: 21.017.09.00.314
Drivers installed: Huawei.4.20.07; Huawei.4.23.13
PS: I already tried with 37736292 and 13712263
Thx Bro
The second code is correct!
If this is not accepted it is because you have already entered 10 wrong codes or you have customised firmware.
Go to www.dc-unlocker.com and download their Client software and read the modem, this should tell you what is going on!
hi I have unlocked my t mobile huewei e583c-1 with dc unlocker put o2 sim in ok comes up o2 now, whats next step! it did it automatically after buying 7 credits I need settings please ,seen them before on forum! now carnt find them when I need them all uk +settings for Spanish providers as well please !can some one post all uk and Spanish providers thank
loopy123 (9th June, 2013)
Thanks for the reply I got the mobile partner and the o2 settings, I went to tools and put in the o2 settings and saved, how do I apply them?? it does not seem to connect to the net, do I need to be doing something else? any further help much appreciated. When I put the o2 sim in it comes up at the bottom everything ok?
i think it because its a o2 mobile sim will this affect it? ringing provider now . it has 500mb of data on every top up! need good Spanish sim and settings please
once you save settings as "new profile" you can have as many APN as you want but you will need to select the one from your profile list each time you change your sim if you only have the one profile saved then it will automatically select that one.
because you unlocked it via dc unlocker did you swap the dashboard on the dongle too, as this wld make it better for you.
How do I do that pal swap dashboard on dongle????is there a way to check ???just ordered a Vodafone data sim see if it works the o2 moble sim did everything but show the globe sine so don't know till new sim arrives
